Page 23 of 35 FirstFirst ... 131415161718192021222324252627282930313233 ... LastLast
Results 221 to 230 of 348
Thread: Solvent adhesives... why don't more people use them?
  1. #221
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Cool, thanks ShawJohn.
    I guess I will have to get to the hardware store now...
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #222
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    Exclamation Don't use tape to form a shape.
    Don't use tape to form the shape before you poor!!!!!!!
    BAD MOVE ON MY PART!
    The tape is too flexible and slows down the curing process as its sealed from the air at the back. Plus its a mare to get it off after without wrecking all your hard work.
    I should have cut and shaped some ABS flat sheet and stuck it in rather than just try and fill the gap. Its curing time could be measured in decades and its just not gone as well as I thought it was
    Oh wel, you live and learn. And like the saying goes;
    "If everything went right that usually went wrong, wouldn't the day be wierry and long?"
  3. #223
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    bugger! doh! arse!
  4. #224
    Aug 2004
    On the edge!
    I won't know just how good or bad it is till its all cured and I get all medieval with the tape
  5. #225
    Mar 2005
    NYC
    I used the ABS plastic repair kit from http://www.electricalconnection.com/...repair_kit.htm . It's a two party epoxy that cures in 15mins flat. I used 3 tubes at 5 bucks each. If you go this route instead of looking for abs and then shaving it down and mixing it with acetone....i recommend that you do not mix too much and expect to sand it down only b/c it's HARD! I used the UV rated bondo to then fill in a little bit. Prime and paint! I honestly would like to try abs shavings with acetone one day. I tried this stuff b/c someone on this thread i 'think' suggested it. Works great.
  6. #226
    Aug 2004
    On the edge!
    I have now removed the tape ! The acetone has done some funny things with the glue on the tape, and its gone hard and burned into the lilli bezel. I have now re-built the side structures using ABS pieces that I cut from the redundant heater vents. It looks a bit rough but then all fab jobs do till they are sanded primed and painted
    Just need to let it all cure now so I can start sanding and smoothing out with a little more ABS mixed quite thinly...
    More news to follow.
    John
  7. #227
    Mar 2004
    Bristol
    john i have to do it! I can't look at that avatar any long and not call you:
    Two Jags!
    My mum saw a jag with the reg 2jag up round where she lives and I believe prescotts brother lives up near there. hehe
  8. #228
    Aug 2005
    Sorry to go OT, but who is that woman bouncing up and down in your avatar?
  9. #229
    Mar 2004
    Bristol
    tut tut, the answer is in My Thread!
    (it's Charlotte Church - she is a welsh choir type singer turned wild pop singer with tits 'n *** flying everywhere and getting ****ed all over Cardiff!)
  10. #230
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by ShawJohn
    Sorry to hear, but on the upside, now the rest of us know. So are you saying that block off the back side with some plastic tacted in place by superglue or something.
    I'm prob would have thougth to do the same thing with the tape and just slowly build up some thin layers, DUH!
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. Replies: 30
    Last Post: 07-28-2010, 11:14 PM
  2. People with tuners who work with radiator NATIVELY.
    By nappyjim in forum General Hardware Discussion
    Last Post: 02-18-2005, 10:24 PM
  3. stupid people ,aking me get a lawyer
    By wizardPC in forum Off Topic
    Last Post: 02-09-2005, 09:14 PM
  4. Ok, people asked, i finally have pics of the "behind the scenes" install
    By Urinemachine in forum General Hardware Discussion
    Last Post: 07-24-2004, 12:20 AM
  5. The bad news is PEOPLE ARE STUPID!!
    By cproaudio in forum General MP3Car Discussion
    Last Post: 08-07-2003, 01:25 AM
