Page 25 of 35 FirstFirst ... 1516171819202122232425262728293031323334 ... LastLast
Results 241 to 250 of 348
Thread: Solvent adhesives... why don't more people use them?
  1. #241
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    can't speed up curing without risking bubbles!
    Find yourself an Injection moulding company in your area and ask them for some non-coloured ABS pellets... If they don't have any they will know where does.
    If you get pellets which include a colour agent this will not melt in ABS and just sinks to the bottom of your mix, I think the colour requires the heat of the injection moulding machine to do its thing...
    HTH
    Time to use the button me thinks
  2. #242
    Oct 2004
    NY
    I know I've said this before, but it seems to have been ignored.... I admit I never tried this solvent method, & it may very well be a great solution for some things, but there is a MUCH easier way.... & is compatable with just about every bezel out there..... words are just words, so I'm going to show a few pictures..... don't mean to discredit this method at all, but for everyone who thinks this is there only or best alternative, I just want to show another method.... hope this helps someone..... when I finish my bezel I'll probably make a thread to show the construction start to finish, but a few shots for now.....
    first, weld/glue/screw/epoxy/ even tape the plastic togeather, even just tack it..... a soldering iron works great for welding plastic:
  3. #243
    Oct 2004
    NY
    then mix this stuff up & put it on.... the consistancy is perfect for this type of work..... when first mixed it is very "flowy" as it sets up it stiffens up slightly before it starts to really cure....
  4. #244
    Oct 2004
    NY
  5. #245
    Oct 2004
    NY
    I did the flat parts w/ no pictures because it's really straigh foward..... fill & sand.... fill & sand, then prime....
    this took all of about three hours on & off
  6. #246
    Oct 2004
    NY
    now moulding the bezel...
  7. #247
    Oct 2004
    NY
    use this stuff as glue to final position bezel...
  8. #248
    Oct 2004
    NY
    after it's positioned I removed it & finish outside or vehicle.... my bezel is slightly different from most here because my screen remains in the dash & the bezel comes off.... positioning is much more of a pain in a setup like this
  9. #249
    Oct 2004
    NY
    tape to make form for moulding....
  10. #250
    Oct 2004
    NY
    this suff dries great for even filling large gaps or even total panel fabrication
  1. Replies: 30
    Last Post: 07-28-2010, 10:14 PM
  2. People with tuners who work with radiator NATIVELY.
    By nappyjim in forum General Hardware Discussion
    Last Post: 02-18-2005, 09:24 PM
  3. stupid people ,aking me get a lawyer
    By wizardPC in forum Off Topic
    Last Post: 02-09-2005, 08:14 PM
  4. Ok, people asked, i finally have pics of the "behind the scenes" install
    By Urinemachine in forum General Hardware Discussion
    Last Post: 07-23-2004, 11:20 PM
  5. The bad news is PEOPLE ARE STUPID!!
    By cproaudio in forum General MP3Car Discussion
    Last Post: 08-07-2003, 12:25 AM
