Page 34 of 35 FirstFirst ... 242526272829303132333435 LastLast
Results 331 to 340 of 348
Thread: Solvent adhesives... why don't more people use them?
  1. #331
    Maximum Bitrate seanz0rz's Avatar
    Jun 2005
    Cal Poly Pomona or Redlands, CA
    oh no theres no substitute for surface prep.
    ive been playing with the coating, its PlastiDip in the rattle can. ive kinda gotten the feel for it, but i will be spraying some more complex items on friday to really get the feel for spraying complex curves and indentations. ive gotten pretty good with a rattle can over the years.
    i have some laquer at home, so i will try that to make sure everything is perfect before i spray.
    if i do paint this weekend, it will be saturday morning.
    1998 Toyota 4Runner SR5 V6 4x4 in Evergreen Pearl Metallic, Lifted, Locked, and Armored. CarPc in custom console with molded touchscreen.
    Pictures
    Photobucket is being updated, if a picture i posted no longer works, please PM me.
  2. #332
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    I found the best way to make the sludge as thick as I could and then paste it on rather than trying to pour it. The more thinners is in it, the longer it will take to set.
    Then carefully using a hair dryer to heat it up, be careful though cause if you get it too hot, you'll get loads of little air bubbles in the plastic that expand and make it look really bad... I know cause I did it
    Warm it up gently, then leave it somewhere warm and dry like a hot water tank closit/airing cupboard over night. And DO NOT under any circumstances, try to sand the gunk until it is absolutely 100% cured and hard, otherwise it just drags when you sand it, and clogs up your paper, and again looks sh1t.
    The ABS gunk method is very affective, last years, and looks extremely well once done, its just very very time consuming
    Lots of patience is required!
  3. #333
    Jun 2005
    ive decided not to make the mistake of rushing this project. i wont start to sand until im 100% sure its dry.
    only one spot is still slightly soft, and its sitting outside in the 85+ degree shade to help in the drying. i will have it this weekend to show off, but not finished. as much work as i have put in to this, im not risking screwing it up and having to redo it.
    im still debating on if i need to build it up more or not. if i can make a thick paste like substance, then i will try, but the liquid method just softens the underlying layers too much and takes longer and longer to dry each time i add another layer, adding days to the drying time.
    Pictures
  4. #334
    VENDOR - Nexations Creations Nexson's Avatar
    May 2007
    I read the first post and want to add that "bondo" isnt a bonding agent and shouldn't be used as one, it is simply to give you a smooth surface and should not exceed 1/4, of course it will crack if it is put under stress being used 2 bond 2 things together, the structure should be strong enough so the bondo can do its job, which is to be apllied light and sanded very well.
    Hell, your project should be sanded flat and smooth before bondo is even applied.
  5. #335
    Newbie YetiMan's Avatar
    Jan 2007
    Warren
    The first post was over two years ago. I bet they know by now.
  6. #336
    Jun 2005
    since this thread has been brought back to the top, time to update my progress after 2 months.
    basically none. i went to test fit the screen and found all my edges had bowed and twisted, and that the entire frame had twisted.
    to remedy this, i cut a piece of glass the same size as the touch panel, taped it where the screen goes, and then filled in the gaps from the front with a very thick sludge. that was my progress today actually, ive been busy with school and vacation and whatnot.
    ill try to get some pictures up next week. after this last coat has cured sufficiently (should be quick, it was real thick and its pretty hot, not so dry) i will trim the opening back to spec, and sand and paint and then i will be very much done with this portion of the project.
    Pictures
  7. #337
    Constant Bitrate ephyouckay's Avatar
    Oct 2006
    ^ Was your initial layer of sludge thick? it seems that the thicker you go the more itll warp. From what it sounds like, the best method is to go thin layers.
  8. #338
    Jun 2005
    yea, it was thick.
    not much i can do about it now but just repair the damage, which i dont mind doing at all. in fact its done, just have to let it dry and then sand.
    Pictures
  9. #339
    Oct 2006
    ok, thanks for getting back to me. I just watned to make sure that thing layers were also makign it warp. I plan on redoing mine with the ABS sludge method tommorow. Already hacked up my current fab... gona sand it down tommorow and bond it.
  10. #340
    Jun 2005
    either thin or thick, you are still chemically disolving the plastic, and it can still warp. my advise is to attach a piece of glass to the back, where the screen normaly goes. this way it will stay true to the screen. i should have done this, instead i used cardboard.
    Pictures
  1. Replies: 30
    Last Post: 07-28-2010, 11:14 PM
  2. People with tuners who work with radiator NATIVELY.
    By nappyjim in forum General Hardware Discussion
    Last Post: 02-18-2005, 10:24 PM
  3. stupid people ,aking me get a lawyer
    By wizardPC in forum Off Topic
    Last Post: 02-09-2005, 09:14 PM
  4. Ok, people asked, i finally have pics of the "behind the scenes" install
    By Urinemachine in forum General Hardware Discussion
    Last Post: 07-24-2004, 12:20 AM
  5. The bad news is PEOPLE ARE STUPID!!
    By cproaudio in forum General MP3Car Discussion
    Last Post: 08-07-2003, 01:25 AM
