Originally Posted by
Big Black Turd
^^ Not true. Did it the other day. Took a large black ABS pipe (I know it was ABS because it said "ABS" in large white/grey letters) and ground shavings off with a dremel. Put said shavings in a jar, and poured acetone in it. The shavings melted down into a nice goopy sludge, then dried into a very hard ABS clump (many many hours later, but nonetheless, dried).
MEK works too, but so does acetone so don't rule it out. You may have tried it on PVC or something, which, in that case, it doesn't work.
