Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Plaster?
  1. #11
    Constant Bitrate coachreed's Avatar
    May 2004
    Lee's Summit, MO, USA
    Start by coating your part with mould release wax or HPV (can't remember what it stands for... basically it is liquid vinyl)... once you have your mould release taken care of, coat the part with tooling gel (gel coat)... usually tooling gel is bright orange... the gel coat will pick up your finish texture... if you have a paint-ready final part, your parts should come out of the mould being paint-ready... once the gell coat is cured, lay-up one coat of fiberglass and polyseter lay-up resin... let it cure and then lay up 2-3 more layers of the same. Now like someone already said, you may need a multi-part mould.. this is if your part has compound contours with negative draft... we can talk more about that later... mulit-piece moulds will be tough and not really for a first attempt... but who knows... we don't know your abilities... then again, with your questions, neither do you (not a slam)... sooo... I'll check back after work... have a wonderful day!
    Coach... aka Randy! (I often forget who I really am!) ;)
    ***Too many pieces and parts to list... maybe someday I'll show'm to ya!***
  2. #12
    Mar 2005
    Quote Originally Posted by coachreed
    Coachreed,
    thanks for a prompt reply.
    I'll let You guys know how it goes. I picked up some plaster today and I'll start working on the mold tomorrow.
    The parts that I am facricating do not require multiple molds - I picked the easy parts first to get things rolling....one has to be able to crawl before running as the saying goes
    Once again, thanks a lot!
  1. Clear Plastic Liquid
    By Tred in forum Fabrication
    Last Post: 12-15-2004, 04:01 PM
  2. question about making a mold
    By zaxxon in forum Fabrication
    Last Post: 07-29-2004, 06:36 PM
  3. custom dash making....
    By ifnh573 in forum General MP3Car Discussion
    Last Post: 10-13-2001, 01:39 AM
