is that modeling clay?
and what are you asking for here?
how to create a dash piece that will let you remove it and the screen or what?
your post isn't real clear....
Hi,
I've fixed my lilliput in dash and I've creaded a frame whit a modelling material,
I've worked and the final result is a product not finished up, the modelling material is white and it is not perfect.
The situation without the modelling material is this:
Someone have any ideas to create a detachable frame?
ITALIANI: DISPONIBILI MODULI OEM GPS:
http://www.mp3car.com/vbulletin/show...214#post639214
Jan Bennett
Hi,
this is the final product:
in photo the imperfections are not seen, but are not an excellent product! My request is that to create a detachable frame, even in plastics so that you seem original, for a perfect integration with the rest of the car.
Now I've seen a site for liquid plastic that is used for create the prototype of some object http://www.prochima.it/prototip/prototip.htm
so you are wanting a COVER? something that will hide the screen - still not understanding you.....
Jan Bennett
You are looking to get a great flush look with how you have the screen installed; correct?
Check out this thread which has a good write up on this matter, or atleast the way I'll attempt it.
HOWTO: Building a removable LCD screen bezel and mount
