Thats gonna be tough. You'd need mechanical help there to keep it all perfectly even and clean. I can understand your reasoning tho, cuz of the texture of your dash.
But its gonna be hard. Dremel is the tool of choice for most of us.
I just pulled my dash to test fit my monitor, and I came up about 1/4" short of putting my Xenarc into the stock double din headunit space. The top and bottom both have little lips that I should be able to take off to make it fit.
My question is: What is the best way to remove these lips without destroying my dash piece or needing to clean it up with any fab work? I would like to just cut/sand/whatever the lips off and be able to use it just like that.
Thanks.
Attached is a pic of the bezel.
Spent so far: $1,755
Check Out My Work Log for Specs/Pics
CarPC Progress[!!!!!!!!!!!!!!].....Installation[---------+].....Pastrami Progress[!!!!!!!!!!!!!!]Don't mess with Texas.
It's not nice to pick on retards!
Car: 2000 Audi A4 Avant 1.8t
Carputer 2.0: removed. Back to stock.
you might consider cutting the top 1/4" of your monitor case off. My Lilliput had about a quarter inch of wasted space in the top. I had to notch a corner to miss a dash bezel mounting clip on my (in progress) install.
That or see if you can inset the monitor behind those lips...
