Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Making Designs in Plexiglass
  1. #11
    Variable Bitrate proTONEd's Avatar
    Jun 2004
    Belgium
    Quote Originally Posted by gizak
    I've done sandblasting on acrylic and it works out ok. I had never done it before so it didn't turn out too great. Make sure you sandblast enough, I thought it was hazy enough to stand out the first time, but when I peeled everything back it didn't look too good. Make sure you use enough tape or really strong tape, the sand will start penetrate it if you sandblast too long (this happened the 2nd time around b/c I wanted to make the logo come out cleaner). Also try and sandblast evenly - as if you were spraypainting. It is possible to have uneven areas still.
    The important thing when sandblasting is to consider hardness or stiffness of the material. Sandblasting on a harder surface, such as glass would require less sandblasting than a softer material such as plastics. Plastics and rubber absorb more power of a collision with a sandparticel than glass would.
    And sanblasting would be the better choice if you have to do bigger surfaces.
    Why is it drug addicts and computer afficionados are both called users?
    Currently : Audi A6 - no install
    Second install : VW Passat '97 CarPC
    First install : '87 Audi 80 CarPC
  2. #12
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    in the tests i've done, the deeper the better. a dremel will work the best if you can get it uniform. Sandblasting is a good method when putting logos in glass but your final application is meant to have light reflect off of the surface which is best achieved with a more aggressive (deeper) technique like the one you have choosen. if you are not happy with the results send it out to get laser etched.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  3. #13
    Dec 2004
    Los Angeles Ca
    oh...if you aren't happy with the results you can maybe approach it in a completely different way. What i was planning to do was get a vinyl sticker printed in reverse then apply it to some plexi, paint the plexi black and then remove the sticker and apply some limo-tint to the back side. then mount some cathodes or leds behind it and when lit you'll see the image, when off it'll be black.
    M10k
    My Car Pc Install
    My Boat Pc worklog
  4. #14
    Constant Bitrate gizak's Avatar
    Feb 2004
    Phoenix, AZ
    Oh yea, I tried a similar technique. I headed over to home depot and picked up a hazy white window film adhesive (white tint). Just draw and cut out your design and stick it! This is the easiest thing to do, but doesn't give you the best effect since it's not etched in and the light doesn't penetrate it from the sides, but it works out ok if you a soft cathode-type light behind it.
    -GiZak-
    Carputer Project: 98% Complete!! *tweakin'*
    Xenarc 7TSV | Opus 150 | Biostar M7NCG400 | Athlon Mobile2200 | Seagate 160Gb | Kingston 2x256mb | BT Holux GR-231 GPS | LiteOn CD-R/DVD| Keyhole Rev. Cam | Zippy Mini-glow Keyboard
  1. I can help with making Adapter Plates
    By brandon in forum Fabrication
    Last Post: 07-13-2004, 06:24 PM
  2. MediaEngine Skin making
    By liquid_smoke in forum ME Archive
    Last Post: 09-13-2003, 08:45 PM
  3. plexiglass question
    By Squeezer in forum General MP3Car Discussion
    Last Post: 07-23-2003, 02:48 AM
  4. Help! How to make a plexiglass case
    By e36mp3 in forum General Hardware Discussion
    Last Post: 05-21-2003, 06:44 AM
  5. custom dash making....
    By ifnh573 in forum General MP3Car Discussion
    Last Post: 10-13-2001, 12:39 AM
