Results 1 to 10 of 14
Thread: Making Designs in Plexiglass
    Variable Bitrate HHdesign's Avatar
    Mar 2005
    Plano, TX
    Myself and a couple of friends went up to a local car store to check out the latest products they were sellin and we noticed this very nice design make into plexiglass. Someone had incorperated an "Infinity" logo onto a thick sheet of plexiglass and then put it over two nice cathodes and two large subs, its kick-***, take my word for it.
    Now plexiglass is an absolute pain to cut if you dont have the right tools. So I've established that.
    Now I was wondering if anyone has tried to use sandpaper to rough-out designs in plexiglass, if so, how did you do it?
    I tried to rough-out a "Jeep" logo onto a sheet of plexiglass to mount over my subs, but I found it very difficult and my tape wouldn't cooperate. If you understand what I'm saying dont bother to read on, I'm about to explain what I did.
    Ok, I got about a two foot, by two foot sheet of about 1/8th in thick plexi and taped out the word, "Jeep", when I say taping, I outlined the letters. I first tried using masking tape, after a try by hand, and then with the automatic sander, the tape eaisly wore off before I could do any real designs. The parts that I did manage to sand turned out nice, I was wondering the following questions... What grit should I use, I tried, 60, 100, 150, and 200. Also, how should I go about doing this professionally, I'm looking to sand clean lines and edges, not faded ones. Anyone with any advice would be much appricated.
    thanks in advance.
    Jan 2004
    Jersey/NY
    one word: router
    I've never used a router on plexiglass, but I'd imagine it'd accomplish what you want relatively easily
    Mar 2005
    Only thing I can think of would maybe be to get a dremmel with a sanding bit, which would offer you at least a little more control than sanding by hand or a power sander. Still not sure how clean a line you could really get with that tho
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    you can have it laser etched pretty inexpensively for best results. router works, or dremels glass etching tool. do a search in www.bit-tech.net there are some great write ups
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Mar 2005
    Plano, TX
    Quote Originally Posted by scott_fx
    Wow thats exactly what I was looking for, the laser etching those guys at www.bit-tech.net do some really nice artwork on their plexiglass. Thanks for all the feedback guys.
    Dec 2004
    CT
    another option is to use a beadblaster or sand blaster, cover the glass in a few layers of that blue masking tape then use an razor to cut out the design then blast it that would give that same effect
    Jan 2005
    Aurora, OR
    You could go to your local sign shop and have them do a cut out of your letters and apply that, then bead blast it. Before you apply the vinyl, paint the back side of the plexiglass some hot color if you want, then apply the vinyl and blast or sand if you are so inclined. The effect should be pretty cool. Try it out on a scrap and see how you like it. Just remember to do everything in reverse order.
    Keep us posted on what you come up with. Pics to if you have them.
    Variable Bitrate proTONEd's Avatar
    Jun 2004
    Belgium
    Quote Originally Posted by bobs987
    The advantage of sand blasting is that it would give a more even effect than power sanding it or doing it manually. Sand blasting is a common practice for putting logos on transparant surfaces. It's even done with glass and mirrors.
    Why is it drug addicts and computer afficionados are both called users?
    Currently : Audi A6 - no install
    Second install : VW Passat '97 CarPC
    First install : '87 Audi 80 CarPC
    Mar 2005
    Plano, TX
    I'm going to try using a dremmel, then the sand blasting see which can provide the most even, clean cut lines. I plan to put this piece of plexiglass over a small storage compartment in the back of my jeep, beneath the plexiglass will be some neon tubes, its the first step in making the cargo area of my jeep an entertainment center.
    Constant Bitrate gizak's Avatar
    Feb 2004
    Phoenix, AZ
    I've done sandblasting on acrylic and it works out ok. I had never done it before so it didn't turn out too great. Make sure you sandblast enough, I thought it was hazy enough to stand out the first time, but when I peeled everything back it didn't look too good. Make sure you use enough tape or really strong tape, the sand will start penetrate it if you sandblast too long (this happened the 2nd time around b/c I wanted to make the logo come out cleaner). Also try and sandblast evenly - as if you were spraypainting. It is possible to have uneven areas still.
    -GiZak-
    Carputer Project: 98% Complete!! *tweakin'*
    Xenarc 7TSV | Opus 150 | Biostar M7NCG400 | Athlon Mobile2200 | Seagate 160Gb | Kingston 2x256mb | BT Holux GR-231 GPS | LiteOn CD-R/DVD| Keyhole Rev. Cam | Zippy Mini-glow Keyboard
  1. I can help with making Adapter Plates
    By brandon in forum Fabrication
    Last Post: 07-13-2004, 06:24 PM
  2. MediaEngine Skin making
    By liquid_smoke in forum ME Archive
    Last Post: 09-13-2003, 08:45 PM
  3. plexiglass question
    By Squeezer in forum General MP3Car Discussion
    Last Post: 07-23-2003, 02:48 AM
  4. Help! How to make a plexiglass case
    By e36mp3 in forum General Hardware Discussion
    Last Post: 05-21-2003, 06:44 AM
  5. custom dash making....
    By ifnh573 in forum General MP3Car Discussion
    Last Post: 10-13-2001, 12:39 AM
