First post here. I am considering putting a carputer/screen in my '92 vette. It would be mainly used for 2 things- GPS Nav, and Data logging/chip burning while I am at the track. As far as hardware/wiring goes, I think I am set, however, I am having some trouble with where to actually put the screen. Now, the widest I can seem to get space in the dash, is 7". It looks like the 7" touch screens have a width of ~ 7.5". I have attached an image of the dash area in question. The radio is non-standard size, and is about 6.5" wide (for reference). The A/C controls, and the status panel above them, stick out about another 1/2 inch past the radio (cant really be seen in the pic).
I'm wondering if anyone can figure out a good way to install a 7" screen in this space. Re-locating the A/C looks like it would be a BEAR (there is a mechanical arm that hooks up to the back of the A/C controller, and it doesnt look like it could be relocated). However, I have no qualms about eliminating the radio (I can just use a radio card in my car pc). Any tips?
the actual screen in most 7" touchscreens (lilliput xenarc) is only about 6" wide, of course you need a little more space than that for the surrounding bit but i have no idea where you pulled the 7.5" number from
Signature: [==||========] 20% complete
That value was pulled from the mp3car.com store:Originally Posted by Nic
ex- the Xenarc 700TS
Does anyone have the exact dimensions needed if you pull the guts out of the case?Dimension (in): 7.75W x 4.75H x 1.38D
hey... you look familiar!
FAQ: Everything you need to know about your Lilliput
page 3
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
My Boat Pc worklog
looks like you'll be able to get the screen to fit, even on that screen there is a metal frame that can be covered my the radio bezel
M10k
My Car Pc Install
My Boat Pc worklog
I guess what I would need to do is 1) cut out a piece of paper for the screen case dimensions, and see how it would fit, 2) cut out a piece for the minimum size if you take the screen out, and see how that would fit. Anyone have the dimensions for #2?Originally Posted by scott_fx
Doh.. looks like #2 is answered in that thread! my bad.
