Results 1 to 5 of 5
Thread: xenarc indash tips "translations"
    Constant Bitrate cyberlancer's Avatar
    Feb 2005
    Gallarate (VA) - Italy
    xenarc indash "translations" tips
    hi, i'm sorry, i know that there are a lot of threads/posts about this question, but i'm starting to work on my range dash in order to fit a 7" xenarc (that doesn't fit very flawlessly, indeed, need to relocate buttons and so on..).
    the problem is that i read all posts about bondo, epoxy and everything related to fabrication issues, but before starting i really need some explanation, cause my knowledges in fabrication, even if quite good, are related to RC model and, since i live in Italy i'm afraid i can make some mistake when buying appropriate products due to the fact that i can't buy from US stores paints or bondoes.
    So please don't get in anger:
    1) which kind of product do i use to glue xenarc front bezel into the hole i'll make for it in the center dash console?
    2) do i need to reinforce the dash-bezel assembly with something else (i.e. glass fiber?) in order to avoid cracking?
    3) wich kind of product do i use to fill gaps in order to make an even finish?
    4) do i use dye or paint to paint the dash after having obtained a smooth surface?
    i used the word "product" because i'd like to know wich "kind" of product i have to use in order to do the works, (since i know that, for example, bondo it's a brand name and not a general words to indicate it...)
    i really appreciate any suggestion/helps.
    many thanx.
    Feb 2005
    is anyone out there?
    Variable Bitrate RS3RS's Avatar
    Aug 2004
    Springfield, MO
    Quote Originally Posted by cyberlancer
    1.) That's where the epoxy comes in. People usually just epoxy the front bezel in place in the dash console.
    2.) Probably depends on your car, if it turns out feeling "flimsy" when you're done, you might, who knows. I've never had to though, in my experience the epoxy has held well.
    3.) To fill in deep gaps to make the bezel flush with the dash so it appears to be one peice, most people use fiberglass reinforced bondo. What I have is in a blue can, is Bondo brand, and is just called "Bondo-Glass Fiberglass reinforced filler".
    4.) You'll want to find a spray paint that matchs your dash nicely. It usually takes a few trys to find the perfect match, so you might consider painting a scrap peice of plastic or something and matching it to your dash before you paint the dash bezel itself.
    Good luck
    Phillie Escalade182's Avatar
    Mar 2005
    Maryland
    Get some pic's. Make the problem more clear.
    Feb 2005
    it could sound strange but these anwers are just fine for me. i'll start work as soon as i'll receive the spare Range top switch unit i've ordered. i've already started work on mu custom case. i'lll post some pics when it'll be something to see ....
    thanx.
  1. Wow: indash Xenarc & motorised VGA TS
    By Scouse Monkey in forum Off Topic
    Last Post: 05-18-2007, 10:34 PM
  2. Xenarc says they will ship the indash in january. HA! lol.
    By big_cali_dave in forum LCD/Display
    Last Post: 10-20-2004, 03:48 PM
  3. Xenarc 10.4" 500nit indash install !!!!
    By lookinco in forum LCD/Display
    Last Post: 09-23-2004, 09:56 PM
  4. Xenarc in DigitalWW indash??
    By Glyn in forum LCD/Display
    Last Post: 01-21-2003, 06:57 PM
