As the distance between the bars was too small, I gave them to a friend of mine and he welded a pice of metal between.
As the monitors are too big for the headrests, I decided to fabricate othere headrests that would fit the monitors I got from Armen (Thanks again!).
As I couldn't find any Ford headrests, I got some random ones wich I stripped leaving me with only the metal bar.
This is how they turned out:
This is the original headrest:
Here you can see that the headrest was too small for the monitor to fit. I've read Altimat's tutorial for small headrests, but these were too small for that.
I then cut other 2 pieces of MDF for the front of the headrest, and attached it to the frame. I don't really trust glue, so I used screws.
I used two pieces of thin wood to attach the monitor shroud to the frame.
Time for the foam to be applied. So I made an MDF box for the foam to expand in.
Foam applied:
interesting..
that expanda foam won't be too soft of ur head?
Damn, nice work so far!! Those monitors kick *** too!!
I can't wait to get mine back from Altimat.
Spent so far: $1,755
Check Out My Work Log for Specs/Pics
CarPC Progress[!!!!!!!!!!!!!!].....Installation[---------+].....Pastrami Progress[!!!!!!!!!!!!!!]Don't mess with Texas.
It's not nice to pick on retards!
