Results 1 to 10 of 16
Thread: removing super glue fog
    Maximum Bitrate CavityCr33p's Avatar
    Jun 2003
    Arkansas
    I screwed up and used loctite on my lucite faceplate, and the bottom of it fogged up (I was patching a corner that didnt stick well)
    Now the front corners are fogged up where the superglue was applied, any idea how to remove this?
    2000 Sunfire build 100%, or is it ever really 100%?
    Variable Bitrate HHdesign's Avatar
    Mar 2005
    Plano, TX
    Just from personal expierence, try Acetone seems to remove just about anything. Be careful though, I'm thinking the acetone might eat through the plastic, if it is plastic. Test it somewhere before using it one your faceplate. An tottaly off the top of my head, I've used simple green for just about anything. I keep a bottle in my car just in case. Try some simple green too, not quite as strong as acetone, but it can clean damn well.
    Jeep Grand Cherokee Laredo
    Kenwood X790 x/ iP500 Ipod Interface
    Elemental Designs 13Kv.2 D2
    CDT ES-620 (omg yayay!!!1)
    NINe.2X, NINe.2
    Jun 2003
    Arkansas
    My co-worker told me that it is chemically bonded with the lucite and that it wont be cleanable...
    any ideas? total suckage.
    Raw Wave wizardPC's Avatar
    Jun 2000
    Nashville
    I'm pretty sure thats a total loss
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    Total spent on wedding so far: $3885.79
    Thanks to everyone for your support.
    I'M DEBT FREE!!
    Variable Bitrate drait's Avatar
    Dec 2004
    NorCal
    You could sand it down through the 'fog' with some very fine grit (800+) wet paper and then polish it with a good plastic polish. Obviously, this will make the material thinner where it's sanded, but at least it won't be foggy.
    Jun 2003
    Arkansas
    Man...that sucks, I guess you learn as you go huh?
    Anyways, I wish I could sell this Crate halfstack and grab a lilliput/xenarc
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    Quote Originally Posted by CavityCr33p
    It could also be crazing. Which is basically small cracks in the polymer caused by a chemical reaction. Either way, I'd try wet sanding it with 1000 grit then 1500 grit. Then a fine polish like Megazuma Final Polish 2. I've unhazed automotive lenses this way but your mileage may vary.
    Clover Grayscale's Avatar
    May 2004
    Arkansas
    Man, didn't i tell you that my superglue that was holding a corner of my lilliput against the housing fogged the bottom right corner of it? Yes, I think I did haha.
    CarPC install is starting to come along again...
    Jun 2003
    Arkansas
    Quote Originally Posted by Grayscale
    You might have!
    Oh well, its not too bad......It will do till I can afford a Lilli or xenarc.
    Gray, buy my guitar amp from me since you are in the same state...puuhhlease?
    May 2004
    Arkansas
    Its just the head right? How much, I think we already discussed this but I am actually wanting a better amp.
    Anyone ever get superglue on their screen?
    That thread was on here earlier, just thought you might wanna read on it...
  1. Removing super glue and bondo.
    By nappyjim in forum General MP3Car Discussion
    Last Post: 10-30-2004, 06:36 PM
  2. How to glue stuff in dash?
    By SuperMatty in forum LCD/Display
    Last Post: 10-13-2002, 05:28 PM
  3. Hot glue in PCI slots
    By ppgt94 in forum General Hardware Discussion
    Last Post: 08-16-2001, 10:59 AM
