Results 1 to 4 of 4
Thread: Custom Bondo/Fabricate 03 corolla
    Mar 2005
    Orlando
    I have 03 corolla S and I have my 7" tv where the stock radio unit is, i need some help and guidance to fabricate, how do i do it and so forth, thnx
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    You got a pretty good spot for the screen there. but the screen is a little too big. If you cut the buttons off I thing you would be able to fit the screen in there perfectly. You could also move the IR receiver and mold that into the dash and use you remote if you ever need to change the settings of the screen.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    IR receiver would be cool in the vents if you never close then
    Constant Bitrate blasterguy128's Avatar
    Feb 2005
    Fort Lauderdale, FL
    THANK YOU 0l33l!!! You just saved me from putting two holes in my dash for IR receivers. That is a really good idea for the air vents.
    Now djkl407 it looks like you have a double din opening there, so the lilliput will fit there, but without the buttons. If you don't mind not having buttons, it wouldn't be too hard(depending on your skills, of course) to bondo the screen into your bezel. I have my buttons covered and just moved the ir sensor to the vent(thx to 0l33l) so I could use the remote. The most important button you would need is power, which is on the remote, but the auto turn-on mod is a good idea.
    I, personally, have never worked with bondo, so I am going to take my first venture into it soon to mold my screen into the bezel.
    Mobo= Epia V
    Ram= 640mb
    Ps= m1-atx
    Screen= Lilly 7" ts
    Hd= 40gig
    case= 1/10 scale model of my car (04 Saturn Ion QC)
    soundcard= soundblaster mp3+
    GPS= Holux gm-210
  1. 2004 Toyota Corolla S Project!
    By PaulDePimp in forum Show off your project
    Last Post: 04-13-2007, 07:31 PM
  2. Replies: 35
    Last Post: 07-11-2006, 07:07 PM
  3. custom case fabrications
    By dim-8 in forum General Hardware Discussion
    Last Post: 10-10-2004, 04:43 AM
  4. Audi A6 custom install carpc with fingerprint recognition
    By ejdeleon in forum Show off your project
    Last Post: 07-07-2004, 04:25 PM
  5. Trouble setting custom resolutions....
    By SinnerG in forum LCD/Display
    Last Post: 06-18-2003, 08:15 AM
