Well after putting things off for quite some time I finally decided I should put some of the parts in my basement together into something of use.
So what switches/buttons/lights would you suggest? Still looking to do a small door from another desktop computer case to hide USB/firewire/switches/lights and am looking for good ideas.
Also there is room below the display for a slot load player.
I had been looking for some help in layout back in this thread and decide to go with a Xenarc screen a while back. I actually am a retailer for Xenarc, but that was not really the reason I went that direction.
Anyway pictures is what you want right... Well OK. Sure hope comcast speeds up cause it's been slow tonight, if the pictures are slow for a little bit sorry about that. I have a good hosting company, but didn't put these on that site.
So I had a spare console sitting around I ordered with 2 extra 12v outlets and covers. This is for the lower console section in my Chevy Avalanche. I also had a new Xenarc housing so I got some aluminum and started cutting, bending and filing and cutting and bending and ...
bent and cut to shape. Sanded to help with epoxy
Still more work, but I wanted to get a layer of primer on just so I can see where I need to work and get it cleaned up and then I plan to try and use some textured paint to get closer to my existing dash: (in that part where the 2 outlets are with the 2 cutouts.
