Gonna use SWC and your joystick port?
WOOHOO
i just won this on ebay:
ok, well maybe not all that...but if you look closely at the bottom you'll see a detatchable face with a bunch of buttons and a volume knob. i'm going to mold that into a flat plate, paint it black to match the rest of the console and mount it in the area where my dvd-rom is. Then i'm going to map the buttons to the appropriate functions in centrafuse...ta daa...i'll finally have high-quality, back lit buttons!
The reason why i'm doing this is i found the one downfall of my touchscreen is that i have to look down to change tracks or adjust the volume. now that i'll have some tactile buttons, i can scan through tracks and select different functions without taking my eyes off the road! KICK A$$!!!!
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
My Boat Pc worklog
actually simpler then that. since i'm using centrafuse and almost everyfunction in it is hot-keyable, i'm going to wire the buttons to an ipac2 keyboard emulator. for the volume knob, i am going to take the guts out and replace it with a phidgets usb rotary encoder.Originally Posted by ddogg_777
M10k
My Car Pc Install
My Boat Pc worklog
nice thats gonna b awsome!! good luck
Soooo... What are you going to do with the rest of it?![]()
I just got the faceplateyou can have the parts that i hack off and dont use
I wish i were better at silk screening. for a lack of a better work, that'd be tight if i could print labels below the buttons too
M10k
My Car Pc Install
My Boat Pc worklog
why dont you just change it to a rotary encoder hooked to the scroll wheel part of a mouse, itd be cheaper than buying a phidget encoderOriginally Posted by scott_fx
Signature: [==||========] 20% complete
already have the phidget. plus my roommate's going to help me write a vb program that will allow me to adjust the volume with it, then apon clicking it i'll be able to use it as a scroll wheel (to scroll through playlists) then at an idle state it will reset to volume control
M10k
My Car Pc Install
My Boat Pc worklog
How much did you pay for it? I mean the faceplate.
$50 shipped
M10k
My Car Pc Install
My Boat Pc worklog
