Results 1 to 5 of 5
Thread: Fabrication materials
    Apr 2005
    Louisiana
    I've read all the tutorials, but now I was just wondering what are all the materials I need to let says install the LCD in my dash, and where can I get them?
    Mar 2005
    What are you looking to use? You can get fiberglass from boat supply shops or hardware stores over in the paints department, sometimes. THe resin for it is always close by. Bondo, go to hardware shop or auto store like Pep Boys, auto zone or whatever, and ask for body filler. Get sandpaper from car store too. and use alcohol or actually grease remover for cleaning of pieces.
    Or look at the thread about using solvent adhesives, too. Good stuff.
    Apr 2005
    Louisiana
    I see that most people use bondo so I guess I will go with that too. Is that all I really need? Other than miscellaneous stuff?
    Newbie Projectwidow's Avatar
    Apr 2005
    Suwanee, GA
    Quote Originally Posted by imaxorz
    it just depends on how in depth your project is. i used fiberglass to strengthen the screen to the plastic where i molded the tv too. then i used bondo to make everything smooth.
    Apr 2005
    Louisiana
    I guess I'll get both. Ty.
  1. Custom Fabrication Work?
    By mattdisaster in forum Fabrication
    Last Post: 02-01-2005, 12:37 PM
  2. Alternate fabrication materials
    By TruckinMP3 in forum Fabrication
    Last Post: 01-28-2005, 06:00 PM
  3. sub woofer box - materials to use ?
    By SAScooby in forum Fabrication
    Last Post: 10-30-2004, 01:16 AM
  4. Good Fabrication Links:
    By Snootch in forum Fabrication
    Last Post: 06-08-2004, 08:10 AM
  5. Dasboard modification and fabrication...
    By JGeek in forum Newbie
    Last Post: 02-27-2004, 07:48 PM
