Why didn't you just take it out of its case?
(uhm, not sure if this posted?)
hey guys, im almost done with molding my screen, but since the xenarc frame is aluminum, im not sure how to get a nice seamless flowing between the bottom of the monitor frame and the bondo (there used to be holes for HVAC knobs, and ive shaved those with a combination of fiberglass and more bondo. right now there is a DVD slot i just added in...)
anyways, is there any way to get this into a more smoother curve. i keep adding bondo and trying to sanding in a curvelike fashion, but after i hit it up with some primer, its not smooth looking at all.
as always, appreciate any suggestions and thanks for reading.
edit: should i just keep primering for like 50 layers in addition to wetsanding? will that help and make it seamless? thanks
Mazdaspeed Car Computer
gotta redo it all
Not sure what you mean?
Take it out of the case? You know how the casings for the 7" screens are plastic?, the one for the 8" is aluminum, and kinda makes it hard to make a seamless molding, unless i just need to shoot a couple thick layers of primer and get that goin.
not sure, thanks for reading
gotta redo it all
I meant that this isn't a lilli that will fall apart if you remove its casing. Basically I was saying to just totally ditch the aluminum and make your own holding for the screen.Originally Posted by Dexter
Gotcha, but damn, that'd be alot more work, and i spent a week fussing over making sure it was straight before i put it in and stuff... I dunno, I suck, im gonna go empty a can of primer on dis biatch. heh.
gotta redo it all
Good idea...Originally Posted by Dexter
Maybe use some bondo spot putty? It's in an orange tube, easy to work with. Hell, I'd recommend throwing on a rubber glove and just using your finger to contour it. Then sand it gently without a board/block. I think the board will just expose the edge again.
yeah, ive got a big tube if the spot putty. i will try that, and yeah i use gloves and just contour it with my finger. i edned up emptying the can of spotfiller/high build primer, i'm gonna wetsand it now with some 400 and try some of the spot putty. i can see it IS building up and getting nicer, but man, its gonna take awhile. oh well, such is the life.![]()
gotta redo it all
I'd give the spot putty a try. When I was putting in my spoiler, I dropped it and chipped the tip right off. (I was ****ed)Originally Posted by Dexter
I took some of that and was able to make a new tip in about an hour sculpting it with my finger. I had to do it in three passes to build it up.
Good luck.
Bondo sticks to metal great just sand it well first. Spot putty is the devil use it very sparingly and only for the very smallest imperfections and pinholes.
Fabricator
