Results 1 to 7 of 7
Thread: Bezel fabrication
    Dec 2003
    Bezel fabrication
    Word... heh, my last dashboard sucks so i'm making a new one.
    I'm just curious about what you guys all use to make custom bezels... i'm working with a Datalux LMV10 screen that's been gutted, so i've got a 10.4" open frame LCD with a touchscreen on it.
    I was thinking of making the bezel out of ABS so i can try the solvent slurry method rather than the glass/bondo/paint route, but i'm wondering, what's the best way to make an accurate, clean square opening in a sheet of ABS?
    Maximum Bitrate Meatballman's Avatar
    Jul 1999
    Hartsville, SC
    For a piece that's not flat (ie, a dash bezel):
    Tape off the edges so you have straight lines. Then score the plastic along the edge of the tape with an X-acto knife. Next take a dremel tool with a cutoff wheel and cut along your lines (the scoring will help keep your cuts straight.) Next get some flat files and use them to straighten, shape and smooth your cuts. They work much better than a sanding block or anything like that.
    After some patience and TLC with the files, you can have very nice straight cuts.
    Dec 2003
    naah, i'm talking about a sheet of ABS, a flat, square sheet
    but i need the opening to be accurate for my touchscreen overlay, the bezel has a habit of interfering with the sensors.
    Jul 1999
    Hartsville, SC
    I'd probably just use a square and a straight edge and some clamps to form a guide and use a router to make the cuts. Routers and router bits can get expensive though.
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    Quote Originally Posted by greenwire
    Score the opening well, drill the center, cut the diagonals with a scroll saw, Dremel, jigsaw and backing, whatever - then fold and snap off the 4 triangles on the score lines.
    Fabricator
    Dec 2003
    Nevermind got CNC time in may
    Jul 1999
    Hartsville, SC
    Quote Originally Posted by Altimat
    Yeah...what he said...that's probably easier.
    CNC machine is of course the best option.
  1. Replies: 58
    Last Post: 05-14-2009, 10:21 AM
  2. How to: Duplicating a radio bezel.
    By Giuliano in forum Fabrication
    Last Post: 02-21-2006, 11:14 PM
  3. Replies: 35
    Last Post: 01-12-2005, 02:10 PM
  4. Custom Secondary input using old radio bezel?
    By anaxagoras in forum Input Devices
    Last Post: 11-03-2004, 10:54 PM
  5. del
    By hanzacra in forum Classified Archive
    Last Post: 03-25-2004, 05:44 PM
