Results 1 to 5 of 5
Thread: 8" lcd for 98-02 accord?
    Feb 2005
    Hi, anyone here who has used an 8" monitor on their 98-02 accord dash? Because I'm contemplating between 7" or 8" for my project..
    Thanks!
    Feb 2005
    anyone?
    Apr 2005
    the LCD inside lilliput 8" is 7-3/8" x 5-5/8" with thickness 7/8". you could use a piece of foam or something to mock it and try how to mount it. I guess you probably need to fabricate a piece as its frame and cover the trash space below.
    Dec 2003
    SoCal - 909
    you've got to cut and trim for a 7" to fit in the double din opening. an 8" is going to require some major work
    AutoPC: M10k, WinXP, gps, wifi, 80GB HD, dvd-RW. SB mp3+
    MediaEngine front end, map monkey, netstumbler.
    gps mouse is on the fritz.....stupid technology
    Maximum Bitrate shizzle's Avatar
    Mar 2005
    Sarasota, FL
    Quote Originally Posted by Cryogen97
    Indeed. My 8" is mounted outside the double din, in front. It works, but the 7" wouldve worked better. If you want to flush mount in the dash, go with the 7". If other options are acceptable, the 8" is a little easier on the eyes IMO. Good Luck!
    Carputer status: [-*---------]
    Im thinking laptop...
  1. Replies: 14
    Last Post: 12-09-2005, 04:03 PM
  2. Wild Things PSone LCD to PC
    By godzi11a in forum LCD/Display
    Last Post: 11-22-2005, 08:13 PM
  3. FS: Tablet PC (8" TFT LCD)
    By BimmiN in forum Classified Archive
    Last Post: 10-25-2004, 01:04 AM
  4. 04 accord lcd
    By fallnangel in forum LCD/Display
    Last Post: 09-16-2004, 07:20 PM
  5. Replies: 4
    Last Post: 03-16-2002, 02:32 AM
