Page 5 of 7 FirstFirst 1234567 LastLast
Results 41 to 50 of 61
Thread: Indash Retractable Keyboard - in progress
  1. #41
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    Quote Originally Posted by daveg360
    I gave this a go a while back for my lilliput screen. Not sure if it was the way I did it or what but it was very juddery. I changed it all to a rack and pinion set up - this works really well but the torque is so great it destroys itself if it jams - seriously if nothing broke I reckon it could jack my car up!
    Where I left off, the problem was noise, but it's because I didn't smooth out the end of the threaded rod so it would clack as it spun inside the lego.
    Any pics, other details on your setup?
  2. #42
    Aug 2005
    Will get some tonight when I put it back in (glued the limit switches in last night)
  3. #43
    Apr 2005
    Boston, MA
    Thanks. Interested to see how you made out.
  4. #44
    Maximum Bitrate pRoFiT's Avatar
    Apr 2005
    Fresno, CA
    Nice, was reading the motorized screen cover thread and thought a keyboard would be sweet. So i bought that little keyboard. Just got it today. Now with a huge machine shop at my work and access to the SLA machine i can make some prototypes.
    Here is my first idea. with keyboard out.
    http://home.comcast.net/~cstrachn/da...out_screen.jpg
    and keyboard in without screen.
    http://home.comcast.net/~cstrachn/da...d_in_clear.jpg
    I think i can fit my screen in my dash with HU and keyboard modded into the slide out ash tray.
    Um, I guess this is where you put something witty.WITTY
    My Web site, in the design stage. http://home.comcast.net/~cstrachn
    Modified RRSkinEditor http://www.mp3car.com/vbulletin/rr-skins/65723-rrskineditor-bugs-fixes-comments-current-progress-outdated.html
  5. #45
    Apr 2005
    Boston, MA
    Quote Originally Posted by pRoFiT
    If you have a machine shop, maybe you want to try this....
    Just use a small piece of small track used for tracklighting. It's small, cheap and strong. I got a couple 18" pieces for like 10 bucks at Home depot. Then you just have to machine a little piece that fits in the track. There should be a plastic end piece that's almost the perfect shape on one end. Just needs to have the flash around the edges removed. You can use that for your prototype. (I tried to tap the plastic cap on mine with no luck.
    Then just tap it and thread it. Attach a motor to the threaded rod and secure the motor to the track and you 95% done and it will be a nice narrow form factor.
    Then tell me what exact brand/part of track you used, machine another fitting and sell it to me
    I've got a bunch of stuff going on, but the plan (unless someone steps up) is to find a cnc guy and try and make the fitting. Not much of a CAD guy and like I said, busy, so i haven't been able to get to it.
    Another benefit is if you had the equipment, you could cnc the "runner" out of plastic and add some contacts to fit the track and you could run power to whatever was mounted via the track if you wanted no wires or worry about catching them in the mechanism.
  6. #46
    n2k
    n2k is offline
    Low Bitrate n2k's Avatar
    Aug 2005
    Couldn't this be done easyer by salvaging the tray mechanism from an old 5.25" cdrom ?
    just my 2c
    .n
  7. #47
    Apr 2005
    Boston, MA
    Quote Originally Posted by n2k
    just my 2c
    .n
    Doubtful. I ripped apart 3 cds before I tried to make my own.
    None were even close in how they worked. The only one that had an actual acturator, it was a tiny one for the head. Maybe 2 inches of travel. There was one other that maybe could have worked but it would have been huge as the mating teeth were molded to the sides of the housing. I cut it down as much as I could and it was still large for where I wanted to put it.
  8. #48
    FLAC NiN^_^NiN's Avatar
    Aug 2004
    Australia, Melbourne
    what about something like this?
    http://www.jaycar.com.au/productView...=&SUBCATID=432
    stepper motor controlled by the PC or Manually?
    only $50 AUD which is cheap would have enough power to slide the keyboard out and back again.
    CarPC Status:
    GPS: 99%
    Hardware: 99%
    Software: 92%
    Case Install: 99.9%
    Dash Install: 100%
    Car Install: 72%
  9. #49
    Apr 2005
    Boston, MA
    Quote Originally Posted by NiN^_^NiN
    I just went with a regular motor with limit switches for simplicity. I have steppers around, just didn't feel like making a PIC circuit to drive it. I'm going to have too many damn microcontrollers as it is when I'm done.
  10. #50
    Apr 2005
    any updates on this?
    you still plan on offering kits??
  1. Laptop keyboard to the PS2 port....
    By claylong in forum General Hardware Discussion
    Last Post: 09-22-2007, 07:29 AM
  2. retractable keyboard
    By Moneyfink in forum Input Devices
    Last Post: 03-16-2005, 03:21 PM
  3. RR 03-12-05 .. Keyboard Support ...
    By guino in forum Road Runner
    Last Post: 03-15-2005, 02:48 AM
  4. 2 part question (keyboard hacks)
    By chuckctv in forum Input Devices
    Last Post: 09-07-2004, 09:24 PM
  5. Disabling BIOS keyboard error?
    By Squeezer in forum General Hardware Discussion
    Last Post: 02-02-2001, 09:29 AM
