plastic primer - paint - possibly lacquer (satin PU I would suggest to try).
There are special plastic paints - look for bumper stuff etc
hi
whats the best way to paint the dash console?
ground - paint - lack
or
paint - lack
on plastic surface
is it possible to use primer over the bondo iv'e made
Primer will stick to things that paint won't - thats why you use it - it 'primes' the surface! Primer is great stuff - without it most paint jobs will be ****!
Just make sure the primer you use doesn't affect the bondo by doing a test on a sample. Best thing to do is go down your auto parts place and look at what they have available.
pssst...... vinyl dye.... Don't tell nooobody!
Duplicolor makes a good plastic primer. Called Duplicolor Adhesion promoter. Then I used auto touchup paint and clear over that when doing mine.
wow that's a nice paint job on your interior shotgunefx.
2001 Acura CL traded for a 2006 Subaru Legacy GT
7" Lilliput Touchscreen
NANO-ITX+m1-atx
512 DDRsodimm
60g SATA Laptop HD
4x Apple DVDslot
digimoto OBDii
mS GPS
mini BT keyboard
relocated HU faceplate
Thanks. It took me forever. Still learning here. I did it at least 5 times trying to get it perfect. The last wasn't the best btw, but I had to get it back in the car. I was sick of driving around with my gauges wiretied to my steering column.Originally Posted by acura cl
I'll probably do it over this summer. I've since aquired a spare dash to make it less painful![]()
here it is, but the light is reflecting, so it looks like ****, dayshot is comming along tomorrow...
never drive faster than your angels can fly..
