Results 1 to 10 of 15
Thread: Bondo..... Which One?
    Maximum Bitrate djXternal's Avatar
    Jul 2004
    Tampa, FL
    Ok I have just recently run into this problem... from this point and earlier i have always been using the bondo all-purpose putty, because thats what my local store carried, but recently they have started to carry bondo autobody filler.... which one of these is the correct one to use?
    Debating on installing a carpc in my Jeep.....
    Tainted Love Cris's Avatar
    Romania
    Quote Originally Posted by djXternal
    I think the automotive one is better. That's what I'll be using!
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    well....first off bondo is a brand......so its kinda hard to know what product you want. Typically the word bondo is associated with body filler and fiberglass/body filler mixtures. Most people start with fiberglass resin, then put a glass/filler mix on top of that, and finish it off by filling tiny holes with lightweight filler. So to answer your question..."which one?" the answer is more or less all of them. However a lot of people just go with 1 glass/filler mix.....i've used bondos "fiberglass jelly" which is pretty easy to use and with enough sanding its all you need.
    secondly, from what i've heard, bondo is actually one of the crappiest autobody filler manufacturers, but because of their emense popularity most stores dont carry anything else.
    PC Components:
    My work log
    May 2005
    MD
    Bondo or similar products should only be used as a skim coat to fill-in pinholes and sanding scratches. It's not reliable to use as your main compound to blend a factory trim piece to a LCD bezel. It will eventually crack and separate. There are better products out there that will perform better altough at a higher cost. I like Duramix 4040 the best. It applies easily (with special gun), sets up fast and sands easily. You can then use a glaze or putty designed for plastic repair to fill-in pinholes and scratches. These products are a lot more expensive but the end result is much better and more professional looking. Here are some suggestions.
    Main blending/filling product:
    Duramix 4040 (http://www.handsontools.com/store-pr...t%3E_9505.html)
    3M Automix 5883 (http://www.handsontools.com/store-pr...t%3E_3876.html)
    Liquid Plastic
    (http://hzemall.com/online_store/onlinestore.htm)
    Putties/Glazes:
    3M Piranha Finishing Putty (http://www.handsontools.com/store-pr...t%3E_4281.html)
    USC Blaze Glaze Finishing Putty (http://www.handsontools.com/store-pr...E_9594770.html)
    SEM Polyester Glaze (http://www.handsontools.com/store/sh...roduct_id=9063)
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    I'm been using the carmix platic repair and let me tell you that it a bargin compare with other fillers that don't that stick hard... you pay more but on the long run you don't have problems.
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    Quote Originally Posted by ED27
    Actually that statement is only half true. While the end result may be much better in terms of strength the end result will look exactly the same. The proffesianality is due the the person who is doing the body work regaurdless of the filler used.
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    For Duramix 4040 (these stuff is expensive especially with the gun) you can use this product SEM: Bumper Repair #68422. These 2 are very much the same but SEM is much cheaper and you don't need that "special gun".
    For ABS plastic, you can mell them yourself. Check out one of the thread regarding to that stuff in this fab forum.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    May 2005
    MD
    Quote Originally Posted by antimatter
    That's a given. I think most people already know that the skill of the person doing the job is the most important but my point is limited to the context of the forum - plastic dash trim work not auto body work. Initially you could have the same looking results but what about a few weeks or months down the road when the lesser quality stuff starts to crack, chip and separate. Doing a professional job is more than aesthetics and what you see on the surface.
    Jan 2004
    California
    I think that there are higher and lower quality fillers but i dont think that the filler is really that important, More so the bonding agent. If you ensure that your bond is good and there is little stress the filler you put on makes little differnce. THe only bondo that i have had crack (the regular bondo) is when i lost the bond due to stress and a bad epoxy job. It wasn't ABS on ABS, i neglected to sand down the paint on th lilliput bezel. Under stress the epoxy gave way leading to a crack in the filler.
    The filler is just that a filler not meant to be a bonding agent. When done right you can have the exact same result as using one of the more expensive plastic mixes. This is my point.
    In that respect you can also have the exact same bond and the exact same bond at a fraction of the cost by using ABS chips and the solvent method. That way the two peices actually melt together.
    Mar 2005
    I use rage gold
  1. smoothly bonding metal and bondo?
    By Dexter in forum Fabrication
    Last Post: 03-12-2009, 11:54 AM
  2. Steps to sand and paint bondo?
    By nappyjim in forum Fabrication
    Last Post: 01-30-2005, 10:47 AM
  3. Very Unique Bondo Problem! Paint Screwing it up?
    By Grayscale in forum Fabrication
    Last Post: 01-09-2005, 12:34 PM
  4. Bondo won't Dry! Just Stays tacky!
    Last Post: 12-05-2004, 10:11 PM
  5. fiberglass or bondo??
    By faiz_23 in forum Fabrication
    Last Post: 05-04-2004, 07:39 AM
