Results 1 to 8 of 8
Thread: lilliput in an e32?
    Newbie kadeswift's Avatar
    Mar 2005
    Florida
    lilliput in an e32?
    any ideas on location for the touch screen?
    Constant Bitrate sheerdark's Avatar
    Aug 2004
    Fayetteville, Ga - USA
    behind the shifter? Wow...that's a strange dash. Nice car, though!
    Mar 2005
    Florida
    I could remove the ashtray and mount on there. but i'm no good at fabrication, any ideas?
    Jan 2005
    Sweden, EFnet #alfaromeo
    I'll post some pics of my E34 Liliput installation, same dash.
    Mar 2005
    Florida
    where did you place the screen?
    Variable Bitrate RS3RS's Avatar
    Aug 2004
    Springfield, MO
    Nice car. Hmm... Hard to come up with ideas for such a unique design. Assuming you want it actually fabricated into the dash?
    I agree with the idea of behind the shifter, it's hard to know without seeing it in person, but it LOOKS like there would be enough room behind the shifter to put a screen without cutting up the dash or anything. You'd just have to fiberglass a "casing" around it to fill in that area and hopefully make it look more OEM.
    Or, like you said, just take out the ashtray and cut out the area below it, and bondo-glass it in there, which is probably what I'd do.
    How much do you like those center airvents? Might be able to take those out, and remove the stereo, then cut the "bar" between the two and fit the screen there.
    Is that left part of the stereo single din? If so, and you don't mind it not really being in the dash, might be able to get something like this:
    http://www.digitalww.com/DWW-7VGA.htm
    Or, forget it all, and put it in a sunvisor...
    http://houseofrage.com/lcd1.html
    Good luck.
    Jan 2005
    Quote Originally Posted by kadeswift
    I removed the ashtray and had my neighbour (who owns a carbon-/glassfibre factory) make a frame for the lilli. The screen is a bit too low, though, and I might remove the OBC, CD and move the vent controls to where the screen is placed now and put the touchscreen a bit further up.
    Pics will follow.
    Mar 2005
    Florida
    Quote Originally Posted by lusen
    Pics will follow.
    Can your friend make me one? or sell me yours when you relocate yours
  1. Replies: 118
    Last Post: 10-22-2010, 03:05 PM
  2. epia m10k + lilliput => gps blocker?
    By NaFooEsi in forum GPS
    Last Post: 04-12-2008, 08:53 PM
  3. Replies: 88
    Last Post: 09-15-2004, 05:38 PM
  4. Lilliput touchscreen problems -- Need Help
    By BrUTaL in forum LCD/Display
    Last Post: 08-20-2004, 08:41 PM
  5. Replies: 5
    Last Post: 04-01-2004, 04:37 AM
