Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 41
Thread: Custom laser cutting
  1. #11
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    You have a CNC laser cutter? <drool> I'm totally jealous . Is it the Versalaser by any chance?
    I may take you up on your offer, I've got some ideas bouncing around in my head.
  2. #12
    Apr 2005
    London, Ontario
    Indeed it is.
  3. #13
    Variable Bitrate lastberserker's Avatar
    Apr 2005
    Seattle
    Quote Originally Posted by DashCommand
    Hey guys!
    Thought I may be of interest to you. If anybody needs some laser work done, I have a 25watt laser engraver/cutter. It can't cut through steel, but it can cut through wood, plastic, rubber, etc...It can etch plastic, burn wood, and can mark metal. It can etch glass, etc... If somebody needs some specific stuff done, let me know and I can give you a really good price. Basically I can do it for shipping plus some material costs. Considering for the most part I would purchase plastic from Home Depot or something, I don't do this as a business, so just let me know if you've got some ideas as to stuff you want done, and I can possibly help. It's a pretty cool tool to have laying around the house.
    Wow, I'm impressed Count me in for a custom bezel as soon as I get my Lilliput and keyboard.
    Do you have some pictures of the laser / your projects? It'd be totally awesome to see what it can possibly do (ok, ok, I'm a picture whore, so what? )
    Asus K8S-MX ~ Athlon 64 2800+ ~ Kingmax MPXD42D-2K 1Gb ~ Seagate ST960822A 60Gb ~ PSK-3100 PS/2 kbd ~ MR-350 GPS ~ Hawking HSB1AP ~ Buffalo WLI-USB-G54 ~ 8" Dynamix TS LCD ~ DSATX ~ XCard ~ TVedia ~ some LCD TV ~ Vista ~ MapPoint 2006 ~ iGuidance 2.*
  4. #14
    Apr 2005
    London, Ontario
    I'll see what I can do for ya lastberserker with repect to pictures...
  5. #15
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    Cool! I've been thinking about making some custom accents in acrylic. An amplifier cover, some capacitor tie-downs, maybe some electronics covers with some labels cut right into them. If I can get cheap prices like these I might tak you up on that offer.
    What is the minimum thickness to the holes?
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
  6. #16
    Apr 2005
    London, Ontario
    Here is an example for you to see. It's done with wood, not plastic, but you can see the possibilities. This was a gift I made for my wife a while back...yes cheesy, but it scored some good points! All work was done with the laser...including the construction of the box. As you can see, it has interlocking sides that were cut to a tooth style edge. Also, the actual puzzle's message was burnt on with the laser, and the puzzle was cut afterwards with the laser.
    As for the question - "What is the minimum thickness to the holes?"
    Well, the laser beam is I think 0.0025", so technically the smallest hole you could make is 0.0025" diameter...realisitcally anything bigger that 1/64" of an inch would work just fine. Also, that isn't really a thickness issue...
  7. #17
    Apr 2005
    Seattle
    This is a very sweet present and a great way to justify 11k piece of hardware
  8. #18
    Feb 2005
    Thats amazing DashCommand
  9. #19
    Variable Bitrate SickVette's Avatar
    May 2005
    Wesley Chapel, Fl
    Dashcommand......very nice work. Just so you know the "tooth style edge" is called a dovetail. Very common and strong joint used in woodworking. Very nice work. There is a place close to me that has about a dozen laser CNC machines for production work. They do piece work for me. I did not know a machine like yours was available. I am going to have to look into one.
  10. #20
    Apr 2005
    London, Ontario
    Hello SickVette,
    Thanks... I wouldn't consider the joint a did a dovetail since the joints do not actually interlock like a real dovetail joint does (Or at least I am under the assumption that a real dovetail interlocks so that it cannot come apart when pulling from one particular direction). At any rate, yes they do exist, however are expensive enough to have to justify the expense with some potential money making ideas (At least I did)...
  1. Replies: 35
    Last Post: 07-11-2006, 07:07 PM
  2. custom case fabrications
    By dim-8 in forum General Hardware Discussion
    Last Post: 10-10-2004, 04:43 AM
  3. Audi A6 custom install carpc with fingerprint recognition
    By ejdeleon in forum Show off your project
    Last Post: 07-07-2004, 04:25 PM
  4. PC Based Radar Detector?
    By chut in forum General Hardware Discussion
    Last Post: 08-13-2003, 05:22 AM
  5. Trouble setting custom resolutions....
    By SinnerG in forum LCD/Display
    Last Post: 06-18-2003, 08:15 AM
