SickVette,
ABS plastic is the same as acrylic, it can go through it like butter. Aluminium on the other hand -- Wow, you must be looking to spend some serious cash. To cut aluminum about 1/8" thick you would need a 1500 Watt CO2 laser at the minimum which would run you anywhere from $30,000 to $50,000+ for a new machine. You would be best off to buy a VERY NICE CNC router for 10-15k that could cut plastic, wood, aluminium, and possibly some mild steel.
LinkBack URL
About LinkBacks
