wow! great find!
Just found this link and felt like sharing. See if you like it, I definitely do![]()
Asus K8S-MX ~ Athlon 64 2800+ ~ Kingmax MPXD42D-2K 1Gb ~ Seagate ST960822A 60Gb ~ PSK-3100 PS/2 kbd ~ MR-350 GPS ~ Hawking HSB1AP ~ Buffalo WLI-USB-G54 ~ 8" Dynamix TS LCD ~ DSATX ~ XCard ~ TVedia ~ some LCD TV ~ Vista ~ MapPoint 2006 ~ iGuidance 2.*
Yeah, I've been eyeing their services for a while. For those that want metal cut, you might check out these guys (havn't used them so I can't vouch for them however.)
Quite impressive technologyOriginally Posted by mushin
As for the "plastic folks," I think I'll order a bezel for my touchscreen + keyboard + buttons & knobs + mike assembly, there will be too many holes for me and my new friend Dremel to handle
Hey guys!
Thought I may be of interest to you. If anybody needs some laser work done, I have a 25watt laser engraver/cutter. It can't cut through steel, but it can cut through wood, plastic, rubber, etc...It can etch plastic, burn wood, and can mark metal. It can etch glass, etc... If somebody needs some specific stuff done, let me know and I can give you a really good price. Basically I can do it for shipping plus some material costs. Considering for the most part I would purchase plastic from Home Depot or something, I don't do this as a business, so just let me know if you've got some ideas as to stuff you want done, and I can possibly help. It's a pretty cool tool to have laying around the house.
id be down for a group buy for the steel laser cut
----][-][--][-][-I-][-][][][-][-I-][---][---][I--][
----][-][--][-][---][-][][][-][---][--][][--][-I-][
][][][-][][][-][---][-][-----][---][-][--][-][--I][
----------------------][-Carputer-|====|75%
How much did you buy this Laser Cutter/Engraver! Is it CNC?
Sounds great! What format do you want, DXF? Or can people make it easier for you and use another format that allows for kerf correction, lead-ins, etc?
Chrysler 300 - Fabricating
http://hallert.net/
I think making a flat shroud for the Lilliput and Xenarc monitors would be key. Most of us can cut & mold it to fit our application, but having a really slick bezel with the holes for the stock controls would be awesome. Anyone up to Autocad-ing these up?
Car: 1997 VW Passat TDI moving to
1985 Mercedes-Benz 300D
CPU: HP ePC 1gig/256meg/250 gig
Status: Ghetto Install w/Inverter,
Xenarc & GPS & RadioShark
ToGo: DC-to-DC conversion, Grease conversion
Not sure if this was targeted towards me, however I can't cut steel.Originally Posted by JuMpMaN6235
Yes it's a CNC laser cutter/engraver. It cost me a little over 11k.Originally Posted by MaleBuffy
I use CorelDraw to control the laser, however CorelDraw can import just about every vector format there is. Basically what I would need is the file in the vector format of your choice and the desired dimensions. With that, I could scale the vector to the desired size. I would also need to know what material you would want used, thickness, etc...Originally Posted by Chairboy
My max size is 16"x12", and depending on material, can be cut to a maximum thickness of 1/4" - 1/2".
