Page 1 of 7 1234567 LastLast
Results 1 to 10 of 62
Thread: E46 7" Xenarc Bezel Germanfreaks
    Low Bitrate Janus's Avatar
    Mar 2005
    BaVaria
    Hi E46 fanatics
    this is my solution epoxied together out of original BMW parts. Prushed with Sata Jet and 2K Glasurit Ralley-black in rough black like original BMW plastic surface. I also made some exact copies in a kautschuk form. Frames are made out of glass fiber epoxy and also carbon fiber round the "mounting ears". call me at kenischi@gmx.de, if you need some details
    Sorry dudes, my pictures were offline, more or less uploaded them again on a more secure webspace
    The frontend is still C.E.S (http://www.ecarpc.de/)
    New pics from mustafs e46 cabrio
    well done
    I will make some better pics during sun daylight
    kenischi@gmx.de
    cheers
    Janus
    http://www.mp3car.com/vbulletin/show-off-your-project/44885-next-xenarc-morex-loves-e46.html
    CTF-H, Janus VA Case, AsusµATX M2N-VM,AMD Dual-Core 5000, Hitachi 7200 2,5", Carnetix 1240, Hifonics Zeus, Alpine Class-A 3558, Eton 16, Eton 13 Center, Eton 12" Eton 12-680/62 HEX
    Variable Bitrate rickster's Avatar
    Feb 2005
    Essex, UK
    looks very smart. Its got that factory look to it! How long did it take you?
    Newbie numberone's Avatar
    Aug 2003
    Stuttgart, Germany
    I would be interested in further detail. Do you probably have a step by step guide of your method?
    http://www.m2visio.de
    |CAR ENTERTAINMENT SYSTEM
    |Epia m10000 w. 256mb
    |20gb 2.5,slimDVD
    |Morex Cubid 3688+ITPS
    |Lilliput VGA+Touchscreen
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    dude i hate you!!!!
    Amazing screen! Pentium M and a 250W psu!!!
    nice one!
    Dec 2004
    TWC SE
    Wow, screen/trim piece looks simply amazing!!!!
    Can you make others to sell? I'd be *very* interested...
    Thanks!
    Constant Bitrate ltrain1007's Avatar
    Jan 2005
    NJ
    i want one
    Go on and do it, do it, Do it 'til you're satisfied,
    Whatever it is, do it, Do it 'til you're satisfied.
    CarPc progress |OOOOXCOOOO| 57%
    Mar 2005
    BaVaria
    Hi Guys
    as already mentioned....copies of this bezel are ready. Call me at kenischi@gmx.de for ordering details
    cheers Janus
    http://www.mp3car.com/vbulletin/showthread.php?t=44885
    Mar 2005
    BaVaria
    The E46 Bezel copy is now fabricated of professional epoxyd material with glass fiber inlet and carbon fiber rovings round the mounting ears and the thin middle part.
    Milka says hello smile
    Here the picture of the raw model:
    Cheers Janus
    Variable Bitrate Hark's Avatar
    Feb 2005
    Atlanta, GA USA
    Really great work Janus. I'm interested to know how you handled relocating the PCB in your pictures - it looks like you just used hot glue? Did you have to take off the long LED light so the PCB will sit flush against the back of the screen? Have you had any trouble with the PCB falling out of place?
    Also, it looks like the back case of the screen can't be attached in this configuration - I was worried about it being right next to the AC vents and possible condensation dripping on to the exposed circuit boards. Did you cover the back of the screen/PCB with anything to protect it?
    Mar 2005
    BaVaria
    Hi Hark
    Thx for your questions and first in want to say, all works perfectly! Relocations of the PCB was first time made with hot glue, pictures you see are from my prototype just to give you a short impression of the back view. Hot glue is sure not the best solution. Vibration can cause problems. Meanwhile i made some plastic distance clip holders which do this job .The platines have enough distance and work correctly. Next the mounting holders (metric m3) are meanwhile of metal and m3 metal inox screws. With 4 super-thin rubber pads between touch and bezel a good solution against displacement. The original Xenarc plastic mounting holders are not really recommendable. LED is still inside, just off place to get the original monitor configuration back.PCB never had any problems of falling out or displacement.
    Attachment points for the the monitor are not neccesary,the bezel is universal for all xenarcs and mm400. I remember that also the original Xenarc attachment points are not able to center the monitor absolutely in middle position. In every direction there´s a little gap. You get detailed information about centering in my mounting instruction information! With a trick it can be easy centered
    Of cause the back of the monitor is protected with a final foil. The whole panel is so flat, that you don´t get problems with any AC car signals.
    For further information call me at kenischi@gmx.de
    Human Pricing!
  1. Grand Prix 7" Xenarc 1 1/2 din mount
    By P0WDER in forum Fabrication
    Last Post: 03-22-2005, 09:57 PM
  2. Xenarc Bezel - anyone use this?
    By gadget in forum Fabrication
    Last Post: 12-15-2004, 11:36 PM
  3. can you donate xenarc lcd bezel?
    By loakster in forum LCD/Display
    Last Post: 08-11-2003, 06:07 PM
  4. 4 SALE -- Xenarc 7" Widescreen VGA + 3 RCA Inputs!
    By JBCrash in forum Classified Archive
    Last Post: 05-02-2003, 05:15 AM
  5. Xenarc 7" Touchscreen VGA Group Buy.
    By Skippman in forum LCD/Display
    Last Post: 07-27-2002, 11:52 AM
