Results 1 to 10 of 10
Thread: How thick should my texture coat be?
    Constant Bitrate Mattkins99's Avatar
    Mar 2005
    Seattle Area
    I'm using the SEM texture stuff and just curious how thick it should be.
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    enough so u cant c ur primer under it and it looks smooth
    Mar 2005
    Seattle Area
    so you mean as little as I can get away with right?
    Mar 2005
    Seattle Area
    also, is it better to do multiple light coats or one thick coat. If we were talking about regular paint, I know multiple light coats is always better... but this is texture coat, so I'm just asking
    Dec 2004
    id do lots of little light coats because that way u dont have to work with dripping and bubbling what i did when i painted my piece was have 2 hot lamps and my friend fanning it with a cardboard box
    Newbie xhazn's Avatar
    Apr 2005
    Seattle, WA
    well, eh... anyone use vinyl paint to paint plastic? My dad suggested that there are better paints to use, but I'm unsure of any specifically designed paint for use on plastic (I thought that's what vinyl's for, anyhow). And should I paint in 80+ degrees, fahrenheit? Has anyone painted in temperatures colder than that?
    Apr 2005
    Chicago Illinois
    you can paint in pretty much anything above freezing jusst need sufficient dry time.
    i would say 50 degrees plus would be good. a painting tip is to warm the can of spray paint in hot tap water for 5 or so minutes this lets the paint warm up and makes it spatter less.
    Brian
    Apr 2005
    Seattle, WA
    Should I use a Wax and Grease remover? Duplicolor suggests this for plastics painting. Has anyone seen results when it is used, and it was not used?
    Apr 2005
    Chicago Illinois
    i would use some rubbing alcohol to remove any residue from fingure prints or anything like that. test a section that is hidden first because it might discolor the plastic or even melt it. When using a cleaner always test a section first.
    Brian
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    I just spray a light even mist coat and don't even get 50% coverage and it looks great after painting. Just make sure you initiate the spray off the part so you don't get those big blobs that first come out on your part. Warming the can in warm water first increases its pressure and improves the spray pattern. I do this with all spray cans.
    Fabricator
  1. Texture coating
    By Stray in forum Fabrication
    Last Post: 03-29-2005, 03:24 PM
  2. texture and color matching for OEM look
    By 98EXL in forum Fabrication
    Last Post: 03-28-2005, 12:04 PM
  3. SEM Texture Plus
    By lostreception in forum Fabrication
    Last Post: 02-16-2005, 12:09 PM
  4. 7" LCD Screen that's under 1" thick?
    By TDIGuy04 in forum LCD/Display
    Last Post: 09-19-2004, 02:19 AM
  5. Burl Wood Texture
    By vladilen in forum Fabrication
    Last Post: 04-24-2004, 07:06 PM
