Results 1 to 9 of 9
Thread: Is Epoxy sandable like Bondo?
    Maximum Bitrate hd54321's Avatar
    Jun 2004
    Los Angeles
    I'm getting ready to modify a single DIN pre-molded radio bracket into a double DIN enclosure.
    The attached picture is what I'm working with (by the way - I HATE autotoys). I'm going to first close off both front pockets (the DIN spot and the pocket) with a piece of ABS Plastic that I plan to cut to the size of each hole and epoxy it into place (with Plastic Weld).
    I want to eventually sand the dried epoxy and cut the new 2-DIN holes. Than, I would bondo, sand, bondo, sand, primer, sand, primer, paint, paint.
    Is this a good plan?
    -HD
    Constant Bitrate blackbravo's Avatar
    Nov 2004
    Southampton, UK
    epoxy is alot harder than bondo, still sands just more work!
    But IMO epoxy sands better (not easier) because its harder to dig a hole in like bondo.
    Still Planning and Scavenging Parts ------Software-----and anything else i can lay my hands on!!! :)
    Acquired a Toshiba Satelite 4000CDT
    HDD`s ****ed new one on way! 30gb Toshiba.
    Maximum Bitrate Rundell's Avatar
    Yup, epoxy is sandable, never tried bondo so don't know how it compares, but I did my entire piece with epoxy and it turned out great.
    Remember AllAdvantage From 7 years ago? IT IS BACK! Now under a new name Agloco
    GET PAID TO SURF THE INTERNET
    Jun 2004
    Los Angeles
    Great! Thanks guys!
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    automix plastic repair is very easy to sand.
    Mar 2005
    Columbus, OH
    You can get something called "finishing epoxy" made by z-poxy, it sands easier.
    e46|700tsv 2005 model|sb51g xpc2.4ghz opus 150|I-bus|XM Direct&cables | slim slot USB DVD-cdrw|Hawking 54g|iGuidance 2.1-HoluxGPS
    sold it all... :-(
    Coming Soon - 2007 BMW 335i UMPC install
    Low Bitrate jimothy's Avatar
    Oct 2004
    Northern VA
    I think you can also add filler (microballoons) that might make it easier to sand as well. Altimat would be the authority on that one though.
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    Yup thats all bondo is - polyester resin with Microballoons (or in the case of Bondo brand - Talc ) added to it.
    Fabricator
    Jun 2004
    Los Angeles
    Thanks for all the suggestions. I began chopping up the radio bracket pictured in the first post tonight. Funny thing is, once I dremel-ed out the pocket, the mounting tabs and a 2 mm sliver of the top, everything fits nearly perfectly. No need to weld in a piece of ABS and dremel out the appropriate hole.
    The 700IDT I have is a little wider than my radio so, as you can see in the picture, it all works out very well (since the radio pocket is wider than the 1/2 DIN pocket). I just need to apply bondo, primer and paint this weekend. I'll return the Plastic Weld and get my $5 back. Wish me luck people!
    -HD
  1. smoothly bonding metal and bondo?
    By Dexter in forum Fabrication
    Last Post: 03-12-2009, 11:54 AM
  2. Very Unique Bondo Problem! Paint Screwing it up?
    By Grayscale in forum Fabrication
    Last Post: 01-09-2005, 12:34 PM
  3. Bondo won't Dry! Just Stays tacky!
    Last Post: 12-05-2004, 10:11 PM
  4. Bondo question.
    By Quattro in forum Fabrication
    Last Post: 08-20-2004, 07:33 PM
  5. fiberglass or bondo??
    By faiz_23 in forum Fabrication
    Last Post: 05-04-2004, 07:39 AM
