Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 48
Thread: HELP with DVD Overhead Fabrication & Mounting!
  1. #31
    Maximum Bitrate LagunaICE's Avatar
    Mar 2005
    Czech republic
    Nice fabrication. BUT how are you going to connect your optical to your unit? I mean you do not seem to consider using USB enclosure and your carpc will obviously not fit between the roof and roof upholster. And having 15 feet IDE cabel is not best idea ever. Sooo.....?
  2. #32
    Oct 2004
    Have you considered popping the face plate off the dvd and painting it to match for a more stealthy look?
  3. #33
    Low Bitrate Man Ace's Avatar
    Mar 2005
    Seattle
    Quote Originally Posted by LagunaICE
    I bought a slim laptop to USB adapter already. It looks exactly like those that come with the encolsures. It has two USB running form it. One for data the other for power. I just bought it before doing this project, os there was no need to buy an enclosure.
    MY PROGRESS: [ | - - - - - - - - - ]
    Current Status: Waiting for Motorized Single DIN TS to arrive.
    Have: Everything but TS
    Need:USB Hubs,All USB Cables, Keyboard & Mouse Solution
  4. #34
    Mar 2005
    Seattle
    Quote Originally Posted by GTPDan
    Very Good Idea! Just would need to match the color ot the headliner.
  5. #35
    FLAC sdashiki's Avatar
    Aug 2004
    Floreeda
    Im going to put my DVD drive (or my radar detector, unsure) in the same spot. I dont have a sunroof so where the controls go I got a good amount of space.
    Im just curious, when my bass hits and when I hit potholes etc, my rearview mirror (directly below this spot) rattles like a *****.
    Have you tested it to see if it skips or anything in that spot?
    ALSO i wouldnt leave any discs in their when you leave your car.
    Ive left CDs in my HU during a hot day and the disc pops out STEAMING hot. I would think that more towards the roof and such, the DVD drive would be recieving (and giving off) alot more heat than lower in the car.
    (All done)
    iPad Mini 128GB, RF 600.5 amp, JL12W0V2, 8 Infinity Components
  6. #36
    Mar 2005
    Seattle
    Quote Originally Posted by sdashiki
    You're going to hide your radar detector in there iwth the front showing? If you are, that is going to block alot of the radar and the detector will be basically useless.
    Have you tested it to see if it skips or anything in that spot? .
    Nope. My whole setup isn't installed yet. I am not worried about it skipping. It is a laptop drive and meant to be portable and handle bumps I'm sure. I wouldn't worry about it. My CD changer is in my trunk next to my subs and it doesn't skip at all.
    I don't really for see heat being an issue. Usually when a HU in the dash gets hot it is from the sun beaming directly on it. My sunroof has a cover (naturally) and I won't be leaving it open much. So the sun won't apply direct heat on it. I guess if heat "rises" then there may be more? But its not substantial enough for me to worry about at all.
  7. #37
    Variable Bitrate HHdesign's Avatar
    Mar 2005
    Plano, TX
    Wow thats really nice looking, good job, really sleek and factory. Is there any thing seprating the drive from the hood of the car? Like some padding or foam? I was thinking that might get hot during the summer, or in direct sun.
    Jeep Grand Cherokee Laredo
    Kenwood X790 x/ iP500 Ipod Interface
    Elemental Designs 13Kv.2 D2
    CDT ES-620 (omg yayay!!!1)
    NINe.2X, NINe.2
  8. #38
    Mar 2005
    Seattle
    Quote Originally Posted by HHdesign
    The actual cover hides the sunroof motor. That is why you see why it is slanted downward. I really am not at all worried about heat. I live in Seattle and it doenst get THAT HOT around here. darn it.
    I tore off the felt today and added some ABS to the bottom trim of it to even it out. I am dropping my an auto upholstery shop tomorrow to check prices and to see if they can match it.
    I am leaning towards painting the black face the color of my headliner or close to it. My car is a silver color and I have spray paint for that. I think it may look less descreet if it was gray.
  9. #39
    Aug 2004
    Floreeda
    The radar dectector does work even in that position. I have mine currently in my glove box just tossed in there, and it works just as well but range is diminished by maybe a couple hundred feet at the most. When I goon the highway (not city driving) I take it out and put it on the dash.
    If it was in the headliner I dont thinkthe range would be diminshed at all because it has a lot less to go thru than the firewall and engine, being in the glove comp.
    (All done)
  10. #40
    Mar 2005
    Seattle
    Cool. Didn't know that.
  1. Slim DVD mounting screw/bolts
    By Jimbo1978 in forum General Hardware Discussion
    Last Post: 01-29-2007, 08:03 PM
  2. 5" DVD DIN adapter for In-Dash Mounting
    By CherokeeChief in forum General Hardware Discussion
    Last Post: 03-17-2005, 03:55 PM
  3. Bug Reports
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-16-2004, 12:25 AM
  4. problems mounting dvd drive vertical ?
    By robert42 in forum General Hardware Discussion
    Last Post: 09-07-2004, 08:44 PM
  5. Mounting ideas for slimline dvd player in dash
    By psyclobe in forum General Hardware Discussion
    Last Post: 02-11-2004, 10:52 AM
