You can try a transparent sheet.
Scan your original guage and retouch it. Print it on a transparent sheet using a colour laser printer. The toner goes on the back of the gauge.
Might work with inkjet, dunno.
My car has no aftermarket gauge faces, and the stock one allows little room to see the pretty lights. I'm thinking about using a film negative which was exposed with a scan of my current gauge face, along with any modifications I desire. The lights will be visible through the transparent text. I'll hopefully add a colored piece of... something... behind the gauge face for daytime use (so that the plastic behind the gauge face is not visible). Has anyone tackled the theoretically simple task of creating a gauge face? I'll have to find out which bulbs I need for indigo style lighting. Has anyone replaced stock bulbs?
Has anyone used Intelliglow Needles? There's an example at http://www.importcarpartsplus.com/Needles.htm . Now that I look at those "Gauge Overlays", as they call them, I noticed how ugly a flat-black negative would look. Is there a way I can make transparent text and numbers in a material?
inkjet, lol. i'd much prefer a laser printBut it's a good idea... If only Kinko's is okay with printing plastic.... I only have black and white laser printers.
I can't even get this speedometer needle off... this idea's scrapped I guess.
use a plastic fork. Make sure to mark your needle positions AFTER the car has warmed up. Just a forewarning, you'll never be able to get them back to the EXACT same position; close perhaps, but not precise.
I've always wanted to use transparency papers, but can color laserjets print white??
I dunno if it will work without a little tweaking. I was thinking the same thing, I scanned my gauge faces and retouched them and was going to backlight it with my rgb leds. Called up kinkos and they said the transparencies are literally transparent. So you'd have to back it with some sort of diffuser or stack a dozen on top of each other.Originally Posted by Chris31
They normally print cyan,magenta,yellow and black.Originally Posted by silencery
Unless you can find a specialised one with white toner, dunno.
If you got access to tektronix printer, it may be a worth a try. They print wax instead of toner, they are much thicker as well.Originally Posted by shotgunefx
I guess its just a matter of playing around with them until you get the best results.
I suppose I'll experiment with a scrap gauge cluster. Anything's worth a shot. Companies makes beautiful aftermarket gauge faces and I want to, as well.
There are printers out there that are capable of printing white but they cost several thousand dollars (read it in PC World or PC Magazine).Originally Posted by silencery
Here's a tutorial that may help. The first part of the tutorial talks about removing the gauges out of a Ford Taurus. Read future down and it talks about scanning, editing in Photoshop, and printing the new gauges.
Taurus Car Club custom gauge tutorial
Note: the gauges have an aluminum gauge overlay installed.
Derek
Progress [||-------]
View my Worklog to see some of my progress.
Downgraded Progress - Starting with another car... 09/13/06
