Results 1 to 10 of 14
Thread: Fabrication
    Jul 2004
    Fabrication
    I am about to start the fabrication of my removable LCD in my dash. I have been reading a lot of the post posted in the section and I hear a lot about bondo. I am looking for the easiest, quickest, and cheapest solution. Though since itís going to be removable it has to have strength because it will be handled a lot.
    Bonding the LCD to the dash bezel I was thinking about using epoxy. Link
    For filling and sanding I was thinking about using bumper repair. Link
    Or liquid plastic. Link
    Any suggestions?
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    send it to me and i can do it for a decent price just pm me
    Jul 2004
    Anyone????
    Dec 2004
    cut ur dash to the size of the bezel - take ur bezel and hot glue it onto the dash from BEHIND dont let the glue seep to the front so tape it up or just use a minimum ammount - then take mr bondo and spread it over mrs dash let it dry sand sand sand and did i mention sand? then fill then sand then fill then sand and once more fill and sand prime it sand it if u need to prime it again then paint it sand it if u need to then paint it again - you dont have to sand that many times but the more time u spend on it the better it will come u can halfass it if u want :-D
    Dec 2004
    Quote Originally Posted by Enforcer
    What he said. Plus you might want to sand it a bit.
    i mentioned sanding like 20 times lol :-D
    Jul 2004
    I'm not worried about the sanding, Ií, more concerned with getting the right materials. Specifically what the exact name of the stuff that ya'll use?
    Dec 2004
    hot glue sticks - bondo body filler - and bondo spot filler and just whatever u want to use for sand paper use a high build primer
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by xdjxklusivex
    Did you? Can't say I noticed.
    <takes tongue out of cheek>
    Dec 2004
    VA
    Could liquid plastic replace the bondo?
    Car Mods
    -no car mods
  1. Fabrication Procedures
    By fLeMaRo in forum Fabrication
    Last Post: 02-23-2005, 01:35 PM
  2. 2003 Altima Dash Fabrication
    By in4no in forum Fabrication
    Last Post: 02-11-2005, 11:51 AM
  3. Custom Fabrication Work?
    By mattdisaster in forum Fabrication
    Last Post: 02-01-2005, 12:37 PM
  4. Altimat new fabrication moderator
    By Zip-Lock in forum Fabrication
    Last Post: 11-13-2004, 11:57 PM
  5. Fabrication Forums
    By kozmo in forum Off Topic
    Last Post: 11-10-2004, 10:00 AM
