Results 1 to 10 of 19
Thread: Has anyone tried exterior fabrication?
    Newbie xhazn's Avatar
    Apr 2005
    Seattle, WA
    I'm interested in playing with fiberglass and adding onto my project car. I've read very short how-to's on styrofoam body kits, but has anyone successfully made a body kit with a decent appearance? I'm also looking into adding some creases to my hood (elevating the center a bit). That may be best done with cutting the hood and adding brackets to raise the center metal up a bit, and fiberglassing the sides to smooth the install. I'm also interested in covering up the rear wheel wells (so that half of the wheel is visible). I was thinking about fiberglassing and adhesing the creation onto the wheel well with wood for the base. Has anyone done any exterior fabrications? Thanks for your input.
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    dont waste ur time trying because if you mess it up it will look funky i would just spend money buying a kit
    Dec 2004
    VA
    I've thought about it for the longest time...would require a lot of matte, resin, bondo, elbow grease, and time, but it can be done.
    It would be a good thing to learn how to glass with, but start off with one of your smaller projects.
    Some people dont have the hundreds to fork over for a kit, xdjxklusivex
    ....I wouldn't cover the rear wells tho
    Car Mods
    -no car mods
    Variable Bitrate HHdesign's Avatar
    Mar 2005
    Plano, TX
    I would reccomend taking a body shop class. REALLY helpful. If you want to do it on your own, go to a junkyard (treasure lot) and get some old hoods, and work on them before jumping into your own.
    I would advise against covering the wheel wells. Flat tires wouldnt be to much fun to change, and if you get a blowout, its just that much more debris to go flying/ having to repair.
    Jeep Grand Cherokee Laredo
    Kenwood X790 x/ iP500 Ipod Interface
    Elemental Designs 13Kv.2 D2
    CDT ES-620 (omg yayay!!!1)
    NINe.2X, NINe.2
    Apr 2005
    Seattle, WA
    My my, I never thought of the flat tire scenario (doh). Maybe I should take a body shop classs (for a lot of money). There are no body kits available for my car. I've just gotten my first car, so I am eager to begin my practice and experimentations with fabrication.
    FLAC Chairboy's Avatar
    Jan 2004
    It's easy, and with a little effort, can come out looking really nice and classy.
    Like this:
    Chrysler 300 - Fabricating
    http://hallert.net/
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    Quote Originally Posted by Chairboy
    OK I give up what are the red things on the hood?
    You can do it but it takes some ability, at least $1000 worth of materials, and a few hundred hours of time. I prototyped body kits for about two years.
    Fabricator
    Apr 2005
    Its not that hard if you've ever done paper mache. I rebuilt the nose cone for my Porsche 944 and repaired my friends Nisson (sp?) Hardbody body kit (missing large chunks) and I never took a fiberglass course, but i did make a near little dragon in art class out of glue and newspaper. Walmart has decent prices on fiberglass and resin. I got a kit from Nappa to repair the truck.
    An idea is to go to the junk yard and buy a stock front or whatever for your vehicle and chop it up how you like, leaving the top/sides where it mounts and building off of that using cardboard, wood, and/or wire. If you have some experiance I would recommend forming foam and slapping fiberglass on top to get those pretty curves.
    Dec 2004
    Like this:
    looks like a life sized lego car haha
    Apr 2005
    Seattle, WA
    Like this:
    Ridiculous! I suppose it's all about creativity and application when it comes to how one builds his fiberglass creation. I'll experiment, I suppose. And read a few more guides on how to fiberglass. Thanks for the input, especially from Altimax; I didn't realize how much fabrication can cost.
