Page 1 of 6 123456 LastLast
Results 1 to 10 of 58
Thread: The LED tails are done....I think
    Jan 2005
    Canada
    Well, I managed to build a set for the '03 sunfire. Not sure if I'm done yet or not. I might try to add a few more diodes here and there.
    Right now I'm running 32 10mm 18,000 MCD diodes in each light. If I didn't have tinted lenses they would be bright as *&#@
    I think they may be a little dim during the day but I have had the pOlice behind me without any trouble.
    Here are the pics.......
    Constant Bitrate CapitaineFritz's Avatar
    Feb 2005
    Laval, Quebec (Canada)
    Really nice look but I don't think it's legal here in Quebec
    Via Epia M10000 / 512 DDR / 10gigs 3.5 HD / M1-ATX / Innovatek 7" TS Screen
    Trunk fiberglassing in progress...
    Need GPS / Aux Input / WiFi
    My Corolla Computer
    FLAC Chairboy's Avatar
    Jan 2004
    Correct. For it to be legal in Quebec, it would have to spell out "Arręt" with the LEDs.
    Chrysler 300 - Fabricating
    http://hallert.net/
    Jan 2005
    Canada
    I'm trying to make a set mounted in lexan right now. The lens on those would be clear with the led's lighting up red. The new set should be legal in Quebec....lots of new cars have them now.
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    How much did this all cost? Any special circuitry that you had to do?
    Jan 2005
    Canada
    Nothing special other that a 25w 8Ohm resistor to get the turn signals to work right. Total cost so far is about $40CAN
    The next version will be upwards of $100CAN I think.
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by blkfire
    I'm thinking of doing the same thing with my tail lights
    Jul 2004
    Berkeley, CA
    BTW: Were did you get your LEDs?
    Jan 2005
    Canada
    I bought mine at a local electronics shop. You can get them on ebay too but I like to know what I'm paying for first so I tested out 10, then I bought the rest.
    The next set should have around 250 5mm leds per light if I can get the pattern made up right. That was the hardest part so far - my lights are curved both up/down and left/right so it takes some messing around to get it right.
    Good luck!!
    Jul 2004
    Berkeley, CA
    Good luck!!
    I don't know of any electornics shops here that have any LEDs remotely that bright. The brightest they had was like 8000mcd... and they called those ultra bright
    I guess ebay it is for me then
  1. Replies: 21
    Last Post: 05-03-2006, 11:28 AM
  2. M1-ATX Led
    By Bravellir in forum Power Supplies
    Last Post: 03-01-2005, 02:49 AM
  3. 3mm LED into 5mm LED holder?
    By Coeus in forum Hardware Development
    Last Post: 01-28-2005, 12:18 PM
  4. LCD to LED or LED meters.
    By silvertoy in forum LCD/Display
    Last Post: 02-17-2003, 11:07 PM
  5. Reset / HDD activity LED
    By JohnB1182 in forum General Hardware Discussion
    Last Post: 07-10-2002, 02:48 PM
