Results 1 to 6 of 6
Thread: disolve resin?
    Jun 2004
    Graham, WA
    disolve resin?
    I was wondering if theres anyway to disolve fiberglass resin. I want to clean off my paint brushes and my mixing can so that I dont have to use a new brush for every layer. I have tried paint thinner, and acetone. Niether worked, im guessing theres prolly something though
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    what u do is right after ur done using the brushs u leave it in a bucket of acitone dont take me out leave it in there and close it when ur not using it and then next time u use it pull em out and wash em and they will be good to use
    Jun 2004
    Graham, WA
    so the acetone will suspend the resin from hardening?
    Variable Bitrate SickVette's Avatar
    May 2005
    Wesley Chapel, Fl
    Acitone will only work if the resin is wet and it will only work for so long. Acitone evaporates quickly. If you are doing several lay ups in one day you will be able to get away with using the same brush but at the end of the day the brush will be toast.
    Maximum Bitrate DeltaFX's Avatar
    France
    If you don't want to leave the brushes in acetone, rince them with acetone, then with whitespirit, and wash them (soap and water).
    Jun 2004
    Graham, WA
    ok ill try that, I gotta get some acetone I checked the garage and we are out. and ya I just dont wanna have to use a new brush for every layer.
  1. High Temperatue Resin?
    By blackbravo in forum Fabrication
    Last Post: 05-05-2005, 07:03 AM
  2. High Temp resin for Carbon Fibre?
    By blackbravo in forum Off Topic
    Last Post: 04-27-2005, 07:59 PM
  3. how to remove dried resin
    By minghi in forum Fabrication
    Last Post: 02-27-2005, 10:29 PM
  4. Where to get polyester fiberglass resin and ...for cheap....
    By Seabass in forum General Hardware Discussion
    Last Post: 07-26-2003, 09:00 PM
  5. Fiberglass resin questions
    By ddt in forum General MP3Car Discussion
    Last Post: 10-02-2002, 01:07 PM
