Results 1 to 9 of 9
Thread: front wind diffuser
    May 2005
    front wind diffuser
    what would be the best way to make this?
    by not using carbon fiber.
    Variable Bitrate nzKAOSnz's Avatar
    Aug 2003
    Christchurch - New Zealand
    big sheet of alloy.
    92 Subaru Legacy Wagon
    Epia MII12000 :D
    Morex 80W
    120G External HDD
    16x2 Charater Display
    Creative IR Remote
    VIA Sereniti 2000 Mini ITX Case
    7.2Ah SLA Tank
    PCMCIA 802.11b
    256DDR Ram
    Diamonds are for girls- wise men follow the stars
    FLAC Chairboy's Avatar
    Jan 2004
    Seems like if you messed up, it would be easy for that to generate forced air lift that reduces your traction at speed by taking weight off the tires.
    Chrysler 300 - Fabricating
    http://hallert.net/
    Dec 2003
    thats looks like a Top Secret under body diffuser. To make one you would probably have to buy the actual lip and make a mold with plaster or rubber. Then throw on some fiberglass and resin.
    Aug 2003
    hmmm. i would have thought that as long as the front lip is lower than all the trailing points - you should be sweet.
    the channels for air running to the brake duct im thinking also create some sort of vacumn down.
    but hey. if you want top performance - get one off the shelf.
    Epia MII12000 :D
    Morex 80W
    120G External HDD
    Creative IR Remote
    7.2Ah SLA Tank
    PCMCIA 802.11b
    256DDR Ram
    May 2005
    i just wanted to throw out all the hot air in the engine bay since i have a short ram intake. o well. this talk is over. thanks. i'll think about alloy... thin light alloy....
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by koisuruusagi
    Use some aluminum.
    May 2005
    Woodstock, GA
    I'd use bacon. Its a little heavy, but with all that heat in the engine bay, you'd have a nice, big breakfast after you get to work in the morning.
    Is this where the witty comment goes?
    97 Black pearl Mazda Miata MX-5 Carpc V2? maybee..
    Elsewhere
    Quote Originally Posted by Stealth97
    How about the Wiki?
  1. BMW E46 Owners with DSP systems and no HU
    By edrock200 in forum Newbie
    Last Post: 05-24-2012, 11:59 PM
  2. How to: Change windows shell
    By IntellaWorks in forum WinNT Based
    Last Post: 04-12-2012, 08:29 PM
  3. Looking for Front End
    By Wiredwrx in forum Software & Software Development
    Last Post: 05-25-2005, 05:00 PM
  4. Front end needed for semi commercial venture
    By Orange Bus in forum Software & Software Development
    Last Post: 04-28-2005, 02:59 AM
  5. So many Front Ends now, we need a Front End to load the Front Ends.
    By LESLIEx317537 in forum Software & Software Development
    Last Post: 04-09-2004, 05:53 AM
