Results 1 to 5 of 5
Thread: What to use to fill in empty spaces?
    Im thinking of moving my monitor into a new spot, problem is its a big empty spot. Is there some type of shapable foam I can use to fill in the empty space and then go over that with bondo?
    Nov 2003
    you could just use a piece of flat abs plastic and bondo, or fiberglass over that.
    -=Chevy CarPC=-
    ETA: When i get more time
    -Custom Fiberglass Case
    -Epia M-10000 Nehemiah 1Ghz
    -Sony CDRW-DVD Drive
    -Seagate 120mb Hardrive
    -Opus 90w Power Supply
    -Lilliput 7" LCD
    Variable Bitrate SickVette's Avatar
    May 2005
    Wesley Chapel, Fl
    ABS is the way to do it. Use an epoxy to bond it in and the feather it in with a body filler.
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    get some styrene foam - used to make composite sandwhich panels and stuff. It is designed to be shaped like you want.
    Or you could try expanding building foam but i hate the stuff as it is hard to trim.
    We have the stuff in Uni, it is blue dense foam that can be sanded and cut easily.
    Aug 1999
    Birmingham, Alabama (War Eagle!)
    I recommend Balsa Foam, it is what Industrial Designers and model makers of many types use for making sketch models, you can sand it, bondo it and even paint over it. It works really well , however it is toxic to breath in large doses, so breathing protection is recommended.
  1. Empty folders!?
    By Rs! in forum Road Runner
    Last Post: 04-30-2005, 11:48 AM
  2. Empty Double-DIN Case??
    By sxt173 in forum Fabrication
    Last Post: 03-29-2005, 03:24 PM
  3. Empty DIN pocket bracket or mount for LCD?
    By PapaPrem in forum General Hardware Discussion
    Last Post: 09-30-2004, 02:47 PM
  4. Make DVD fill screen under media engine
    By Mikesz in forum Media Engine
    Last Post: 09-24-2004, 05:57 PM
  5. empty drop-down housing for 7" screen
    By FiSKARZ in forum LCD/Display
    Last Post: 05-08-2004, 04:14 PM
