Anyone?
Ok I am semi-happy with my LCD bezel fabrication so far (the epoxy harden a little more over night).
However after doing a test fit of the LCD I noticed I made a mistake. I made the bezel beveled instead of straight (I butted the plastic piece up against the dash kit which was believed).
Does anyone have a possible solution to my problem?
Anyone?
Take your piece of plastic and cover it with blue masking tape...the waxy kind of tape. Make sure where the tape is directly below the gap is nice and smooth. Now attach the piece of plastic from the backside temporarily. Once the piece is attached fimrly mix up some body filler....Rage is best for this application. Wipe in body filler in the gap. Make sure you get a nice fill in the open area and be as gentle as possible to move anything. Let the body filler dry and remove the plastic piece. Now you can shape the boddy filler and sand smooth. Done properly this will give you a perfected fitting curve and fill the gap.
I think I follow you. Take a look at a picture of the inside of that bezel. I used some of that blue tape to tape off the inside of the bezel when I was expoxying it. How would the body filler react to the expoxy?
Body filler does not stick well to epoxy. You may want to try a epoxy-based filler made from epoxy and microballoons (microspheres, cab-o-sil, etc.) instead.
I'd tape the screen, install it, then fill the gap.
Fabricator
i dont understand your problem your fist post isn't that clear please clarify
Image that the black like is the bezel and the red line is the LCD. See how the screen isn’t butting up against the bezel? That’s my problem.
I have never had a problem with body filler adhering to epoxy. Ofcoursee I do not sand the epxoy smooth...usually 80 grit. Then body fill. Personally if I was doing the project I would use the monitor to get the form but I do not think it is a great idea for someone who has never done it before to use a costly piece to try it out on. That is why I suggest the plastic.
So people what's your experience with body filler and epoxy?
If this doesn't work I don't know what I'm going to do. What do ya'll think??
