Results 1 to 10 of 16
Thread: torching acrylic edges?
    Springfield VA
    Don't ask me why, but last night I was watching 'Unique Whips' and they are doing this install in an Escalade - looked like 2 JL subs in a fiberglass box, with 2 JL amps mounted on top. Anyways, they were also putting in some acrylic and hooking up some leds to give it that 'glow' look. So I see the guy with a butane torch torching the edges of the acrylic. I know that there is a method of 'flame polishing' the edges of acrylic, but I didn't think it could be as easy as taking a butane torch to. Anyone know anything about this, or done it before?
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    No, but thanks for the info!
    Fabricator
    FLAC evandude's Avatar
    Mar 2005
    Maine
    Sounds like an interesting idea... could work, but i wouldn't believe it until I saw it. Anyone got any acrylic and a torch handy to try it out on?
    But don't take it from me! here's a quote from a real, live newbie:
    Quote Originally Posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    eegeek.net
    Springfield VA
    well after some more 'ing - I found that it is best to have a 'clean' flame - with more oxygen in it.
    heres a good link:
    http://www.bayplastics.co.uk/product...ch(polish).htm
    When I get a chance, I think I will bust out the torch and give it a try
    Springfield VA
    Quote Originally Posted by evandude
    well flame polishing is a professional way of polishing acrylic, but from what I have been previously told, the proper tools were cost prohibitive to everyone except professionals - so I pretty much had my mind set on sand paper and cream polishing compounds. But if a simple tourch will do the same thing as the expensive tools, I'm willing to drop $30 at Home Depot!
    of course it works... lmao.. nobody ever done this before ??
    Springfield VA
    I haven't - have you?
    Mar 2005
    I work for an automotive interior company and we do a lot of prototypes for the automakers and for auto shows. When it comes to polishing acrylic or polycarbonate, we use a different method. There is a chemical called Rez-n-Bond that is specific for "gluing" together these types of materials. It actually melts the materials together. When this material is put into a tea kettle and heated into a steam, it can be used to polish by placing the areas you want to polish into the steam. Be careful, for one it polishes very quickly and it is a hazardous material that requires a respirator and is flammable. Anyway just thought I would mention it.
    Variable Bitrate SickVette's Avatar
    May 2005
    Wesley Chapel, Fl
    Flame polishing does work but you have to be careful. It can cause the edge to roll if it gets too hot. I used to flame stuff and occassionally still do but my prefered method is sand and polish using a compund and a wheel. The finished product is alot better then with a flame but takes alot more time.
    I am going to have check into Rez-n_Bond....sounds really cool.
    Springfield VA
    SickVette - can you provide some more details on your sanding method - i.e. what grits, what compounds work? I don't have access to a wheel, but would you think that a dremel would work?
    That Rez-n-Bond stuff sounds cool, but I think I would prefer to either torch or sand...
  1. fill the edges
    By bmwperson in forum Fabrication
    Last Post: 09-07-2004, 01:32 PM
  2. Wanted: Someone who can built acrylic cases
    By excess in forum Classified Archive
    Last Post: 08-30-2004, 12:46 PM
  3. What to use to "glue" plexi glass or acrylic?
    By riddle14 in forum Fabrication
    Last Post: 04-19-2004, 01:01 PM
  4. Gluing vinyl to acrylic
    By MP3DUB in forum General MP3Car Discussion
    Last Post: 10-27-2002, 01:28 AM
  5. acrylic case, anyone tried it?
    By Kajo in forum General Hardware Discussion
    Last Post: 04-17-2001, 10:04 PM
