Results 1 to 5 of 5
Thread: What kind of Bondo is exactly needed?
    Jun 2005
    As well as what is the best primer and paint to buy. And where can I get all this. Can't wait to do the dash. Will post pics of the whole process. Thanks for the help.
    Low Bitrate pastypyro's Avatar
    Nov 2004
    Austin, TX
    Home Depot has everything I needed. I used plastic primer and standard spray paint from the same brand. I'm sure experts will chime in later. There is bondo glass for filling larger spots and bondo body filler for smoothing it out.
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    Body shop supply companies have absolutely everything you will need.
    Fabricator
    Jun 2005
    Thanks guy, going to get everything ready, and look for some free time.
    Variable Bitrate SickVette's Avatar
    May 2005
    Wesley Chapel, Fl
    If you have a body shop supplier in your area it would best if you bought Rage body filler and SEM paint products. SEM has the primer, paint, and if you want texture spray.
    Home Depot has the products that will work but Rage is far easier to use then Bondo brand and SEM products are made for plastics. SEM also has factory matched colors if you want to go that route.
  1. Very Unique Bondo Problem! Paint Screwing it up?
    By Grayscale in forum Fabrication
    Last Post: 01-09-2005, 12:34 PM
  2. Bondo won't Dry! Just Stays tacky!
    Last Post: 12-05-2004, 10:11 PM
  3. fiberglass or bondo??
    By faiz_23 in forum Fabrication
    Last Post: 05-04-2004, 07:39 AM
  4. My project for the day - advice needed
    By ddt in forum General MP3Car Discussion
    Last Post: 12-02-2002, 08:51 AM
  5. what kind of bondo?
    By schrodos in forum General MP3Car Discussion
    Last Post: 09-06-2002, 09:44 AM
