Results 1 to 4 of 4
Thread: Sanding Plastic Primer
    Low Bitrate pastypyro's Avatar
    Nov 2004
    Austin, TX
    Okay, the dash piece is finally done and primered. It is very smooth but could still benefit from some sanding before painting. How do you reccomend to sand it? It is on its 3rd layer of plastic primer.
    I have some 400 but I'm not sure if that would just strip the primer completely. Thanks.
    Variable Bitrate SickVette's Avatar
    May 2005
    Wesley Chapel, Fl
    I would try 600 wet. You might have to do a few more coats depending on how thick the primer is.
    Nov 2004
    Austin, TX
    I used 400 after the third coat of primer and applied everything in a very fine mist. Between coats of actual paint I used a very fine sanding sponge. It looks pretty nice, not bad a for a first shot at any fabrication.
    May 2005
    Wesley Chapel, Fl
    Excellent
  1. Plastic Weld?
    By slboytoy in forum Fabrication
    Last Post: 08-31-2006, 12:51 PM
  2. Help With Sanding and Painting Interior Plastic
    By xhazn in forum Fabrication
    Last Post: 05-06-2005, 08:18 AM
  3. Sanding Straight Edges
    By phatchink in forum Fabrication
    Last Post: 01-12-2005, 10:01 AM
  4. 'Plastic grain' paint effect
    By mp3oplecarrier in forum Fabrication
    Last Post: 11-13-2004, 07:45 PM
  5. best plastic adhesive/filler?
    By sohr in forum Fabrication
    Last Post: 06-22-2004, 02:28 PM
