Results 1 to 4 of 4
Thread: Help me out
    Apr 2005
    Help me out
    Okai this is what ive done so far, pulled out the centre console, hacked up the double din slot so the lcd fits, and ive taped it in place. The tape holds it enough for it to be mounted back and even used, but im not trusted tape.
    Heres some pics
    Whats a good way to attach the lcd to the frame? because theres nothing i can really screw into in the lcd is there.
    Variable Bitrate SickVette's Avatar
    May 2005
    Wesley Chapel, Fl
    On average we take the monitor apart and bond the monitor right to the factory piece and then refinish it to look factory or custom. It takes a little bit of work but is not bad. Scan through some threads on here and you will find a ton of information on how to do it.
    FLAC IntellaWorks's Avatar
    Jun 2004
    I second the first motion.
    Check out the "Fabrication thread"
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
    Jul 2004
    Bond the monitor/LCD's bezel not the screen.
