Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: My 2002 Honda CR-V Xenarc fabrication thread
    Raw Wave justintime's Avatar
    Apr 2005
    I'll try to keep this thread updated with progress.
    Status right now: Test fitting Xenarc screen, deciding best way to make it work.
    Looks like this is a very close fit that could look factory! If anyone has examples of how to shave off the sides of original Xenarc housing, please point me in the right direction.
    A few pics of my findings so far... Test Fitting only!
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
    Variable Bitrate RS3RS's Avatar
    Aug 2004
    Springfield, MO
    Looks like it's going to be a nice install!
    As far as the 1/8 inch, really rough grit sand paper?
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    Dremel? But you will probably need steady hands...
    Tainted Love Cris's Avatar
    Romania
    Quote Originally Posted by RoyN
    That's what's I thought, but if don't have steady hands, and didn't work much with the dremel, don't, you won't cut it straight, plus the size you need is way to small, so get a sandblock and use a low grit sandpaper, maby 80 grit, so you don't dig too much, but step by step. using a sandblock allows you to get a straight finish.
    Apr 2005
    Good idea. This way I can go little by little until fit is just right (and 'tight')
    How about the bottom part that I need to trim off? I think I need to dremel it first. And then sand with grit.
    Also, here is a screenshot that details the placement of the housing:
    click for image
    Quote Originally Posted by Cris
    2002 Honda CR-V
    Romania
    Quote Originally Posted by justintime
    click for image
    If you use a dremel, be very carrefull, as if you don't cut it straight here, you might regret it (ask me, I now that now... ). If you ask me, a very fine saw (make sure it's really tight and straight) will do the job perfectly.
    Apr 2005
    Thanks for the pointers. I have decided to sand the Xenarc's front frame, until it fits. I will then glue it to the car's housing, and bondo/sand the 'joints', as well as paint the recessed area.
    I think it sounds like a plan, should look mondo factory.
    2002 Honda CR-V
    Maximum Bitrate TimmyM's Avatar
    Aug 2003
    Federal Way, WA
    I would use a belt sander, stationary if you've got access to one. If not clamp it down and use the belt sander on it. Even a good palm sander would work. I have the Porter Cable model 333, it works great. Use about an 80grit for the palm or 120grit for the belt.
    Apr 2005
    Should I worry about melting the plastic if I sand this thing?
    2002 Honda CR-V
    Aug 2003
    Federal Way, WA
    possible. go slowing and lightly with the belt sander. with a palm sander you less likely to have tha problem. You might try with a peice of simular plastic. you could also try a table saw if it will lay flat. I've cut acrylic that way.
  1. What's with the sudden flood of newbs?
    By ShinkunoNamida in forum Off Topic
    Last Post: 03-29-2007, 02:43 PM
  2. Browsing eBay - Xenarc for Honda owners
    By rajah in forum LCD/Display
    Last Post: 03-02-2005, 08:34 AM
  3. Replies: 88
    Last Post: 09-15-2004, 06:38 PM
  4. Honda Civic Type-R 2002 TFT Dashboard
    By vtecpinguin in forum LCD/Display
    Last Post: 08-21-2004, 04:50 AM
  5. Xenarc Meta FAQ
    By Skippman in forum LCD/Display
    Last Post: 08-23-2002, 04:11 PM
