Results 1 to 10 of 17
Thread: Pc case made from hardboard
    Jan 2004
    I am making a case for my mobo/pc components out of hardboard ... and i was just wondering if anyone had any ideas for a better way of attaching the sides of the hardboard (to the other pieces of hardboard)...
    currently i am just using metal hinges... but they arent too strong..and are kind of expensive if i use alot and make it more sturdy... im looking for a cheap, compact, and sturdy way of making a case out of hardword... without having to make it any larger
    AT mobo
    Intel Pentium MMX 233mhz
    ESS Solo PCI soundcard
    Linksys NIC
    Irman
    Nov 2004
    use blocks of wood and screw into them or possibly buy aluminum L pieces and cut to length
    Jan 2004
    hmmm yea , i was thinking about the blocks of wood... except i think i already made the pieces of hardboard too small for anything that big.. (meaning the bottom piece of hardboard is only slightly bigger than the mobo itself)
    i might try that.. but if anyone has any other ideas, feel free to help me out
    AT mobo
    Linksys NIC
    Irman
    Variable Bitrate nzKAOSnz's Avatar
    Aug 2003
    Christchurch - New Zealand
    use thin aluminum L sections on the outside of the wood.give it a stronger edge, tidy things up, and its cheap. To fasten it - your choice of glue, screw, bolt, rivet etc.
    92 Subaru Legacy Wagon
    Epia MII12000 :D
    Morex 80W
    120G External HDD
    16x2 Charater Display
    Creative IR Remote
    VIA Sereniti 2000 Mini ITX Case
    7.2Ah SLA Tank
    PCMCIA 802.11b
    256DDR Ram
    Diamonds are for girls- wise men follow the stars
    Jan 2004
    what type of glue would hold aluminum (or steel?) to hardboard?
    AT mobo
    Linksys NIC
    Irman
    Nov 2004
    i dont think there would be a good way to glue it unless you drilled holes in the hardboard to allow for more surface area. If you do that, than just use epoxy.
    Jan 2004
    Jersey/NY
    supposedly that gorilla glue is good for metal.. try that junk out.. $5 at homedepot or lowes or whatever.
    Jan 2004
    Quote Originally Posted by Tuckie
    so your saying in order to use epoxy, i should first drill holes in the hardboard where i am going to attach the L brackets? Or instead of drilling holes to be used with glue, i should use epoxy?
    AT mobo
    Linksys NIC
    Irman
    Aug 2003
    Hmmm. things i would try - but would depend on the size of the L brackets. Say if you had 20-30mm+ overlap then i would try araldite, epoxy, or some sort of contact adhesive. If you were going to glue - i would hit both surfaces with a 100-200 grit sandpaper. Also - with glue - a screw or two of some sort may be a good idea
    Epia MII12000 :D
    Morex 80W
    120G External HDD
    Creative IR Remote
    7.2Ah SLA Tank
    PCMCIA 802.11b
    256DDR Ram
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    Quote Originally Posted by wizawuza
    I recommend Home Depot.
  1. PC Case?
    By Nickernack in forum General Hardware Discussion
    Last Post: 12-22-2004, 12:32 PM
  2. Question about ITX-PD/3677 and 3688 DC Deck PC Case
    By m3rdpwr in forum General Hardware Discussion
    Last Post: 12-21-2003, 07:47 AM
  3. Book PC case
    By FreznoSmooth in forum General Hardware Discussion
    Last Post: 12-29-2000, 11:10 PM
  4. Book PC case
    Last Post: 12-16-2000, 10:23 PM
