Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Dash Layout Help
  1. #11
    May 2005
    I haven't had time to take off the controls to see how deep everything is... I was thinking that I may be able to put the controls between the arm rest compartment and the shifter. There's currently just an empty space there (covered by a piece of plastic), so I may go the junk yard, buy an extra control set, and cut away at it to see if I can somehow arrange the controls to fit in this space (e.g. move the right-most control, the location control, to a location under the fan speed and temp control). I have a couple of ham/amateur radios I'm running towards the bottom part of the dash (where it curves), so that space isn't available to move the HVAC controls.
  2. #12
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    Quote Originally Posted by WxGuy1
    It looks like you could fit them into the bottom of that upper panel if you arranged them into a triangle configuration like that.
    Fabricator
  3. #13
    Jun 2005
  1. Help on custom dash for Caddy STS
    By Slaughterhouse in forum Fabrication
    Last Post: 12-14-2006, 06:47 PM
  2. 3rd Time's the Charm??? Mercury Cougar Dash Lilliput
    By antimatter in forum Fabrication
    Last Post: 08-07-2006, 12:21 PM
  3. trying to mould dash.... pls advise...
    By CA 3000GT in forum Fabrication
    Last Post: 06-07-2005, 05:51 PM
  4. 2003 Altima Dash Fabrication
    By in4no in forum Fabrication
    Last Post: 02-11-2005, 10:51 AM
  5. Need some help with dash layout
    By gadget in forum Fabrication
    Last Post: 12-09-2004, 01:18 PM
