Results 1 to 10 of 14
Thread: What type of wood should I use
    Dec 2003
    South West, FL
    Hello everyone,
    question for you all .. I would like to replace the cardboard panel on my trunk floor with a piece of wood , so I have something to attach my case to.
    The problem is I am at a loss as to what tpye of wood to use. MDF would be my primary choice but i thought that the weight would be an issue. The other possibility is particle board , but my concern with that is warping in the heat.
    can anyone throw some advice my way?
    Variable Bitrate SickVette's Avatar
    May 2005
    Wesley Chapel, Fl
    You can use Birch plywood or from Home Depot it is als called sand ply. It is multi layer cabinet grade plywood. Very attractive, strong, and light. It is your most expensive option but the product is worth the extra money.
    Mar 2004
    North Delta, BC
    Agreed, plus MDF is turns to ****e when it's wet, so I wouldn't really put it anywhere where there's a chance it might be exposed to moisture.
    Progress: [II--------] 20% - Gettin there...
    Low Bitrate odleon's Avatar
    Atlanta
    go with 1/4" plywood.
    Maximum Bitrate Snootch's Avatar
    Sep 2003
    Tampa, Florida
    Use some 1/2" MDF, and paint it with some fiberglass resin.. It'll be waterproof.
    WORKLOG
    Asus P5N73-AN Mobo/Celeron E1400 2Ghz Dual Core CPU/2Gb GEIL PC3200/120GB HDD/DSATX PS/8" Phylon TS
    Webpage
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    Try some of this stuff and let us know how you like it.
    Fabricator
    Phillie Escalade182's Avatar
    Mar 2005
    Maryland
    my parents have star board in their boat, inside the cabin, all of the non structural walls are starboard, its really neat how easy it is to work with. I helped my dad install some marine-grade jbl's and it cut through jsut like wood but smoother. its very strong, yet easy to work with.
    May 2005
    Wesley Chapel, Fl
    Altimate.....good link. That looks like a good material but I could not find a price on it to compare it to other materials. I am going to check into that more.
    Regular plywood, especially 1/4" does like to stay flat unless it is attached to some kind of frame. There are not enough layers in it. A 7 to 11 layer plywood is much better for this application.
    Escalade......thanks for responding to my PM.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    MDF ought to work. If the cardboard isn't soaking up the water, the MDF won't either. Weight ought not be an issue if this is the floor of the trunk.
    Otherwise, go for 1/2" plywood to avoid warpage.
    Want to:
    Mar 2005
    Maryland
    Quote Originally Posted by SickVette
    I grew up near the water, so materials like star-board and marine grade vents/grilles are easily assecible to me.
    http://www.marisafe.com/Store/ViewCa...p?CID=35800000
    click on the bold text and it'll tell you how much it cost for different sizes.
    its really not bad prices and its a resin material so you can get it in any color you want without worrying about chipping it, even if you do end up covering it with carpet.
  1. Replies: 1
    Last Post: 06-10-2005, 04:09 AM
  2. computer into wood enclosure
    By nsmoller in forum General Hardware Discussion
    Last Post: 01-21-2005, 08:36 PM
  3. Bug Reports
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-16-2004, 01:25 AM
  4. Problem with connecting 2 Type II pcmcia cards to a Type III slot.
    By AVmobile in forum General Hardware Discussion
    Last Post: 01-28-2004, 10:14 PM
  5. wood dash materials
    By infinitiqx4 in forum General Hardware Discussion
    Last Post: 06-17-2002, 10:32 AM
