Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Molding
    Apr 2005
    Queens, New York
    Molding
    Hey guys, I am just wondering how much it would cost to get my 7inch Xenarc molded into my car. I have a 2002 Mitsubishi Galant. Here is a pic (mine is not Carbon Fiber....its silver)
    am i lookingat like 500 or over.
    My max limit is like 300
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    Variable Bitrate SickVette's Avatar
    May 2005
    Wesley Chapel, Fl
    Price would determined by two things. The finish you want on the piece once completed and how difficult it is to move the AC controls. Just for the molding work and to put a high gloss painted finish in base coat/clear coat I would charge 250.00. But then there is the moving of the AC which could be easy hard to say without taking the car apart. Overall.....the job should cost between 300.00 and 400.00 to get a top notch finished professional product.
    For a little more heads up. I only use PPG and Dupont paint products. The materials alone will often cost 100.00 bucks or more for the kind of finish I apply. Same finish that is on the outside of your car. You will find various prices but keep in mind the various finishes. Making the panel look like carbon fiber is also possible or wood grain...if you want to spend the money.
    Apr 2005
    Queens, New York
    AC Controls already moved the down. ALl i need it to get it fabricated now. And i dont need a fancy fancy paint job...just to look like the stock silver.
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
    May 2005
    Wesley Chapel, Fl
    Do you have a picture of what the stock silver one looks like?
    Apr 2005
    Queens, New York
    kinda hard to see but this is my car.....
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
    Variable Bitrate RS3RS's Avatar
    Aug 2004
    Springfield, MO
    Should be pretty easy to do, just move the a/c controls down, make a few minor cuts, epoxy, bondo, sand, primer, paint.
    Do you have any fabrication experience? You really could save yourself a lot of money, unless you're just really no good at this kind of thing or something.
    Apr 2005
    Queens, New York
    Yeah i def have no fabrication experience. I am good at hooking up stereo equipment and stuff like that but i never fabricated before. What do you think this should run me. I dont need to move the AC controls ===already done.
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    tooooooo easy!
    FLAC Chairboy's Avatar
    Jan 2004
    Seriosly, just buy a replacement piexe and mess around with it, might be something you're good at and you don't know yet.
    Chrysler 300 - Fabricating
    http://hallert.net/
    Apr 2005
    Queens, New York
    What are all the materials i need? Can someone give me an exact list? Also where to get them?
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
  1. Molding Methods?
    By nFiniteTuning in forum Fabrication
    Last Post: 02-13-2005, 08:20 PM
  2. Will molding a dash void a lilliput's warranty?
    By mykolJay in forum Fabrication
    Last Post: 06-29-2004, 09:48 PM
  3. Using buttons after molding Xenarc
    By MSUC5Vette in forum LCD/Display
    Last Post: 04-02-2004, 09:39 PM
  4. molding in a touchpad
    By Cordell in forum Input Devices
    Last Post: 04-10-2003, 03:58 PM
  5. molding
    By Cordell in forum General MP3Car Discussion
    Last Post: 03-22-2003, 06:42 AM
