Results 1 to 10 of 11
Thread: candy red taillight problem
    Nov 2004
    New York
    probably not the right section to post...but here goes. I Just received my new led taillights, and knew I was going to candy the lens all red (instead of just the inside being all red which are the ones I bought). So after doing so today, I realized that one is darker than the other, and they have a fair amount of cloudyness or haze to them. If you look really close, they are speckled. I believe this is from the spray nozzle on the Testors can. I would like for the darker one to be lighter (like the other one), and somehow fix the haze and speckle problem and have them apper really transparent again (like when I applied the first or second coat). I read in another forum that it is possible to wetsand the taillights with approx. a 2000 grit paper and not damage the lights at all, but I'm not sure if this would help my problem. So instead of joining that forum and going through all the registration, I figured I'd check with you guys (my best friends ) first to see if anyone has ever done this and knows a solution. Thanx in advance!!!
    Via epia M10000
    12.1" VGA touchscreen
    XP Pro
    OPus 150W
    120 GIG Maxtor
    512 DDR
    Geforce 5500 Videocard
    Audigy NX USB sound card
    Wireless Keyboard & mouse
    Panasonic slim line -slot load
    w/ usb adapter
    IRMAN
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    hey well i did smoke my friends tail lights and i did experience the clowdy look on one and the chrystal clear on the other not sure how to fix it tho i would try to wet sand it with 2000 grit but its basicly just like using a piece of printer paper and just wetting it make sure that if u do wet sand have like a spray hose hooked up and make it spray ontop of the piece the whole time give it a shot! good luck
    Variable Bitrate Supermike's Avatar
    May 2004
    AZ
    Could it be the preassure in the can drops off to a degree after painting the 1st one? Those Testors cans are small, maybe use a new can for the second light?
    "Protecting Privacy and Free Speech Online"
    http://www.eff.org/
    Nov 2004
    New York
    I'm really not sure, but the first one I painted is the worst one. It looks as if the paint may have somewhat dried in the air before it hit the light. Afterall, it was like 90 degrees when I did it. Would that matter??!!
    Via epia M10000
    XP Pro
    OPus 150W
    120 GIG Maxtor
    512 DDR
    w/ usb adapter
    IRMAN
    Nov 2004
    New York
    thanks for the advice..I will try to wetsand them and see...has anyone else ever had a similar problem and fixed it? Thanx!!
    Via epia M10000
    XP Pro
    OPus 150W
    120 GIG Maxtor
    512 DDR
    w/ usb adapter
    IRMAN
    Maximum Bitrate jzgt's Avatar
    Mar 2002
    Quote Originally Posted by NYCdesignkid
    You can wet sand them - I have used 2000 grit and more harsh paper on many cars with cloudy head/tail lights, then use some compound and some wax to get rid of the micro scratches. It works well... It won't fix the color issue - that is probably (as suggested) a pressure issue - more paint may be forced out with the higher pressure. I'd also recommend throwing several coats of clear on there. That will allow you to wet sand and polish for a great looking and smooth, durable finish.
    - Jeff
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    Warm the can for better atomization. Polish the testors to make it shine better after its fully cured. I had the same problems and will use Folia-Tec next time.
    Fabricator
    Dec 2004
    hehe my friend just got a ticket today for the tail lights ;-)
    Oct 2003
    WI
    What kind of ticket can you get for red tail lights?
    Fabricator
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    not red
    Quote Originally Posted by xdjxklusivex
  1. Hard audio quality problem: Noise / Ground loop?
    By Burat in forum General Hardware Discussion
    Last Post: 09-09-2004, 07:08 AM
  2. I can't connect my hard drives + fan problem
    By haisook in forum General Hardware Discussion
    Last Post: 02-03-2004, 10:42 PM
  3. psone screen video problem
    By WILD9 in forum ME Archive
    Last Post: 11-27-2003, 01:38 AM
  4. cordless phone problem
    By jstrain in forum Off Topic
    Last Post: 06-24-2003, 12:09 PM
  5. Fuel tank burst of gas...problem???
    By PoBoy in forum Off Topic
    Last Post: 07-02-2002, 10:19 AM
