Results 1 to 10 of 10
Thread: What Next?
    Jun 2005
    What Next?
    Here ares some pics of the start of my boot build. I have cut a very tight fitting false floor to mount the PC and amp to however I am unsure as to what route to take now. How shall I go about fabricating the sides to the boot?
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    mask it off and then fiberglass it and then you can build a lil design or mold fleece it fiberglass it bondo it sandit prime it paint it and youu will have a hotass lookin trunk how ever you want it to look i would put 2 subs on each side
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    you could just build the sides with mdf and then carpet that. it'll give you a clean flat edge and great final result
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Jun 2005
    Kent, England
    yeah thats close to what i'm doing/have done before and it works well. looks stock and always give you solid wood to mount anything onto in future if you need to
    Jun 2005
    Any advice for me taking the fibreglass route? what do you use to ensure a clean release? masking tape the area then I've heard to use a releasing wax. Any particular products I should look for? Once I have taken the mould of the walls where do I go from there?
    Thanks for the advice so far guys.
    Jun 2005
    I'd like to add another panel to sit on top of the amp and pc so the tops are flush with it and the wiring is hidden out of site. The walls are going to be tricky though. If I was to mask off the edges and fibreglass like you say.
    Dec 2004
    Los Angeles Ca
    fiberglassing to the contrours of the trunk won't look all that pretty as a final product; but if you want to go that route first use some auto wax and apply it to the metal as a precautionary step. then i usually us aluminum foil and cover the area. apply the fg resin/cloth directly on the foil and then let it cure. you can putt a layer or two down then pull it out and add more till you're happy.
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Jun 2005
    Quote Originally Posted by scott_fx
    I was thinking more to get a mould to work off so I can create a nice curve for the interior edges.
    Dec 2004
    yeh exaclty what scott_fx said mask it down foil it up i heard u cn use seranwrap for a relase agent bt im not sure how that works i never used a realease agent i just pull hard and it comes off lol but make ur mold then make ur shape on it and fleece it and glass on again
    Quote Originally Posted by andy@ukcars
    the best releasing wax in the world is car wax.. not the ****e in bottles but the old fashioned shoe polish style tins.
    woks wonders that do
